Man I need front fenders
   / Man I need front fenders
The other thing the factory steerable fenders have over the home brew “cut in half trash can on a metal rod” have is a suspension.
Note the flexible mount
If fo some reason the fender strikes the tire, theres a chance it’ll swing out of the way.
More complexity and engineering than you think.
That’s why a new pair can be 3 grand
   / Man I need front fenders #62
Or just buy the generic one from their supplier
You will probably also need the zf brackets: A&I Products VLD1830 Four Wheel Drive Conversion Plate S 2Pack
So... $800+ some nuts and bolts.
Still an expensive solution, but I guess if you bother with a cab ...
Kubotas don’t have Carraro or ZF axles….
At least mine don’t.
But hey, that was a good find for other tractors!
I bother with a cab because I’m a full time farmer running a pretty big operation. Fenders protect not only from mud, but broken glass.
   / Man I need front fenders #66
any one find a set of fenders that will fit l60 .I was out the other day and what a mess on the tractor
   / Man I need front fenders #67
Can't help think that poly 45 gal drums and some ingenuity plus flat bar steel could not solve that problem.
Those drums are nice thick poly and already shaped for the task.
   / Man I need front fenders #68
Yes just got the drums today will get the flat bar and see what i can comme up whit .
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
207281 (A52708)
207281 (A52708)
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
