mamafudge
   / mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
   / mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
   / mamafudge #6
Clean & tighten all 4 battery cable connections.
   / mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
   / mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
