mamafudge
/ mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
/ mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
/ mamafudge #6
Clean & tighten all 4 battery cable connections.
/ mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
/ mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
/ mamafudge
2+2nd less =4. Problem fixed. Bad ground. Thanks for the help
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A65056)
2017 GENIE GTH-844...
2024 CATERPILLAR 299D3 XE SKID STEER (A65056)
2024 CATERPILLAR...
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
2018 RAM 3500 4X2 S/A DUALLY TRUCK (A69167)
2018 RAM 3500 4X2...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
