Making gas cans great again
   / Making gas cans great again #91
Actually that's not a filter, it's a flashback arrestor, supposed to stop flame from entering the can
   / Making gas cans great again #93
I just ran into another design problem on gas cans. I have one of the push button type cans that someone gave me but I had never used. I needed to drain the gas out of a project car, so I needed all the cans I could find. When I took the spout off, I found a permanently mounted screen in the can. I was able to pull it out with a little work, a screwdriver and some pliers, but think about the concept. They put in a filter to catch any crap when you fill the can, but it will go right into the tank when you use the can to refuel anything. The only thing it does is keep the can clean.
That is the "flame barrier" which bankrupted Blitz. Lawyers claimed a simple screen would prevent flames running inside the nozzle from reaching the inside of the gas tank.
Plenty of evidence to the contrary, but good enough to convince ignorant jurys that Blitz was negligent for exploding flaming gas cans.
Try this for fun: put 1/4" (or other small amount) of gasoline in a soup can. Throw lit matches into the soup can. Gasoline never ignites but always smothers the lit match. The reason being inside the soup can gasoline vapor is either too lean or too rich for combustion. There is one fine line on the way down to the liquid where the mixture is just right. Possible brief "poof".
   / Making gas cans great again #94
The ones I have lasted for years before they started cracking, never leaked anywhere as you could bend the spout and place it in the tank of whatever you're filling before upending the gas can.
Now as someone pointed out, they're too small diameter at the base flange and leak like a sieve.
This is the one I was talking about, notice..."Discontinued"
EZ-Pour has the correct nozzle for a Wedco can.
   / Making gas cans great again #96
Maybe it's different in Canada, or maybe I'm in the minority, but I spilled a lot more with the old cans. I think a lot of you are remembering the good old days with rose coloured glasses. My gas cans leaked at the base of the nozzle. The plastic bendy straw style leaked at all the joints. Turning a 5 gallon can upside down as you tried to get it into a small hole guaranteed some leaked first - even with a funnel.
Then there is the fact that with this ethanol gas, it has a shelf life of months, and it gets much worse when vented. The automatically sealing cans keep the gas fresh longer (although steel is really the way to go and I saw a link for some nice ones on page 2 maybe?)
I love the auto sealing nozzles, especially for filling chainsaws. Yes it means a little extra time, but I'm saving that in spilled gas and keeping it fresher. I'm happy with the tradeoff.
I also use an electric pump for larger jobs now. Spills less again and it's easy.
I get my water directly out of a well without any filters, so I appreciate my ground having less spills.
*pro tip, when I fill I try to fill on the gravel driveway and when stuff did/does spill (still using some 30+ years old cans), lighting it on fire helps get rid of it quickly
Preventing spills but burning what does happen to spill--is there an advantage to putting potential pollutants in the air instead of the ground?
   / Making gas cans great again #97
Like the old saying: Dilution is the solution to pollution.
   / Making gas cans great again #98
Preventing spills by burning what does happen to spill--is there an advantage to putting potential pollutants in the air instead of the ground?
Absolutely. Generally speaking, combustion converts volatile substances to less harmful ones that can float away in the air and diffuse down to infinitesimally small concentrations.
Whereas if you spill a big batch of petroleum onto the ground, it can permanently ruin the groundwater once its in the soil and water table and unable to evaporate.
   / Making gas cans great again #99
On my 5-gallon can, I drilled a small hole at the location where they show the push-in cap, then put a screw in it--loosen or remove the screw to pour. Cheap and no leaks. (American-made screw, by the way! Unlike all the replacement nozzles from you know where!)
I use a golf tee.
   / Making gas cans great again #100
Government regulators do not use the products they regulate.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
