making diesel engine run quieter
/ making diesel engine run quieter #21
Rob:
A big contributor to diesel engine noise is injection pressure as well as combustion chamber shape. As injection pressure rises (to meet applicable emission levels), the "clatter" gets louder.
One notable exception to that was the Caterpillar 1693 TA. It always sounded like it had a bunch of ball bearings rattling around inside.
/ making diesel engine run quieter #22
Daryl,
Just to add a bit, the HUEI injection system used on some Cat's(& Ford P/S) have very stout springs needed to close the poppet valve, contributing to some of the noise as well.. This may be why some folks see the DI's as being noisier..
/ making diesel engine run quieter #23
Interesting????? My engine machinist buddy says the opposite, and my BD135 direct injection is very loud, and the NHTC48DA indirect ijection is much, much, quieter. I'll check again. He said that the precombustion chamber helps muffle the noise of the fuel oil igniteing, and then the pressure wave/flame front washes out of the release port and over the top of the piston. He also stated the the direct injection just sprays right over top the piston top, and the noise is caused by the same flame front impacting the piston top, and some slight piston skirt slap until the piston warms up and expands. Then the noise quiets down a bit.
/ making diesel engine run quieter #24
Just my experience. I have a 65 hp, 4 cyl. Mahindra that has been giving me a starting problem since I received it last April.
A factory tech. was here all day yesterday, trying to figure out. When all the obvious things were checked out, he went to the timing. Turns out the timing was slightly off. This apparently did fix my problem, but, the first thing I noticed was that the tractor was much, much, quieter, and I couldn't smell the exhaust. Wow, what a difference!
/ making diesel engine run quieter #25
Well I can only offer 6 years of expierence of working with these engines. The diesels I worked on came in a pre-cup or direct. Basically the same engine but with different heads and pistons. We dynoed a lot them with a water brake dyno or some were used as gen sets. We loaded them with a water ground tank. They were Deutz diesels all using Bosch systems. The pre-cups rattle just like my Kubota.
/ making diesel engine run quieter #26
</font><font color="blueclass=small">( Rob:
One notable exception to that was the Caterpillar 1693 TA. It always sounded like it had a bunch of ball bearings rattling around inside. )</font>
Each injection event on a modern high pressure diesel injection system is about equal to firing a .22 Magnum rimfire round in energy and speed, thereby resulting in the greater amount of noise emissions.
/ making diesel engine run quieter #27
HGM:
Caterpillar isn't using the Hydraulically Actuated Unit Injection on their new engines. They have went to compound turbocharging and paid the EPA fine for particulate emissions. However, next year, 007, Cat will have to add an EGR system like DDEC has in place now along with particulate traps in the exhaust header. MB as well as Volvo have the EGR also. DDEC's EGR units are causing a bunch of headaches and the fuel mileage is down the toilet as is Caterpillar. My '06 Cat is right around 4.5 and so are the Detroit's. Of course, the consumer will pay for the difference in the long run. The benchmark of '07 will be that the exhaust will be cleaner than the intake air....but at what price?
Cummins of course is out of the Class 8 market, concentrating on smaller vocational units and stationary power. The rub is that it will all spill over into the consumer marketplace with diesel pickup trucks and car engines being outfitted with the same gadgetry.
The thing that just astounds and amazes me is that the engines made for the agricultrial market have no such emissions gadgetry and still meet Tier 3 and eurpoean standards while using non electronic injection, no EGR and no catalytic conversion units in the exhaust tract.
I don't know the answer but it seems to me that the large displacement diesel engine builders either cannot or will not accept design changes that will make their engines emission compliant and still maintain a reasonable level of efficiency.
Physically, if you took a fully dressed DDEC3 engine and placed a fully dressed DDEC4-5 engine beside it, other than the distinctive green colored block and domed valve cover, the engines don't look or sound anything alike. Caterpillar on the other hand, other than the huge compound turbo assembly and the air to coolant heat exchanger don't look or sound all that different. I can't really comment on Volvo or MB physically, I just get close up and personal with Cat and DDEC.
In light of the '06 emission requirements affecting engine longevity, DDEC has reduced their warranty on internal engine components, camshafts and injection parts. Caterpillar has went to a subsidized warranty.
In our shop, I used to never see a green motor in for repairs. They were always yellow. Now green has outpaced yellow and MB is a strong contender too.
/ making diesel engine run quieter #28
I used to turn my old 220D by hand using the fan. Think the manual on my 240D says to use a wrench on the driveshaft pulley. Did my 220D valve adjustment a couple of times myself. Have always had a shop do the 240D. Get it done about every 2-3 years.
Guess that diesel clatter is injection ignition clatter, from what other folks are saying.
I remember an old Chevy pickup once that came into our service station, clattering away. My dad adjusted his valves for him, and it idled gentle as a lamb. This was before Chevy went almost exclusively for hydraulic valve lifters.
You're supposed to do the valves stone cold. My dad did the Chevy's while it was running. You'll end up with more clearance cold doing them warm or hot in most cases because the valve stems will expand more than the overhead valve hardwear above the head. It's also kinda nasty doing them while the engine is running. Think my dad was looney in some cases. He'd grab hot spark plug wires in his bare hands, too. He's 86 now.
Ralph
/ making diesel engine run quieter #29
5030
"Cummins of course is out of the Class 8 market"
Where did that come from?
/ making diesel engine run quieter #30
Tim:
Cummins Engine could not make the cut as far as emissions requirements were concerned for 2006 and unlike Caterpillar, they declined to pay the fine and continue making non-compliant engines.
DDEC, MB and Volvo were all compliant in '06 though for '07 more advances in emissions control (and the corresponding loss in fuel efficiency) will have to be made as well as changes in the fuel delivery system to accomodate '07's ULSD fuel.
Speaking of ULSD fuel, I wonder how agricultrial engines and tractor engines in general will act on the new fuel. The sulfur is a lubricant for the injection pump and injectors and the absence of it will probably have a detrimental effect on those components. I know for certain that Mr. Lucas and I will become good friends.
Cummins Engine still builds engines, however, not in the class 8 on road arena. Personally, I've always considered the new generation Cummins engines to be glorified boat anchors just like the 2 stroke Detroit engines........just an expensive way to burn diesel fuel..... /forums/images/graemlins/grin.gif
/ making diesel engine run quieter #33
</font><font color="blue" class="small">( Speaking of ULSD fuel, I wonder how agricultrial engines and tractor engines in general will act on the new fuel. The sulfur is a lubricant for the injection pump and injectors and the absence of it will probably have a detrimental effect on those components. I know for certain that Mr. Lucas and I will become good friends.
)</font>
My understanding is bio-diesel, like the 2% blend now required in Minnesota, helps to lubricate again. Might be one solution?
--->Paul
/ making diesel engine run quieter #34
I stand corrected. We don't deal at all with volvo. Freightliner, Western Star, Peterbuilt and Kenworth only.
I do know that the older model ISX engines were very troublesome and many were replaced under warranty.
Hi First I want to say thanks to you and everbody else who responded with all the great info. I guess I'll start with setting the valves and proably get the injectors rebuilt. After that maybe I'll look into the engine timing although I guess thats probably best left to a professional.
I still plan to look into changing my exhaust as well. My tractor has the XL cab on it and I was thinking about rigging the exhuast to run up the front corner like alot of the newer cab tractors have.
A couple more questions have come to mind also. First, I'm wondering what engine oil is best ie: should I use a synthetic oil or stick with a good quality 15W-40 regular diesel oil? Also I've always been told that a diesel engine should run more or less full out or at least at higher RPM to be efficent. I guess what I'm asking is would it be okay run it with say a brush hog on it at half throttle or is that hard on it.
Thanks again to everybody who responded to my previous question.
/ making diesel engine run quieter #37
If you're talkingabout running a 540 mower with 1000 pto and adapter- that might be do-able, if hp and grass allows without lugging. I wouldn't run 540 mower less than 540 as you need blade tip speed to get good cut and there's the lugging. I like15w-40 and regular oil changes for dsl engines due to higher contaminents than gas eng. I guess if you have the $ for syn oil and same interval, it's up to you.
Hi Thanks MMM for the tip on running my mower at 1000 pto. My mower is heavy duty with free swinging blades and if I only use in that mode for grass cutting I'm thinking that should work okay.
/ making diesel engine run quieter #39
How many hours are on the tractor? Like I said in an earlier post, just about all the noise is from the exhaust. I use a 10 foot twin blade Bush Hog behind my 685. I generally run the engine from about 1500 to 2000 RPMs depending on ground conditions. If the load lugs the engine down to 1100 RPMs, I drop down a gear. 2200 RPMs on the engine is when the PTO speed is at 540 RPM.
My tractor has about 4500 hrs on it. You could be right about the majority of what I'm hearing is exhaust noise. The muffler that was on when I got it was shot so I replaced it with a non Case after market one. Its only half the height of the other muffler but twice the diameter. I'm pretty sure the other one was the original. Any ideas on what size muffler I could use to quiet her down. Like I said earlier I'm thinking of running the exhuast up the side of the cab so a long narrow one would be ideal.
By the way I enjoyed the pics of your place. Your 685 looks to be in a lot better condition than mine. A dairy farmer owned mine before me and I think it it spent a lot of time covered in the other stuff cows produce besides milk.
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
Ford Tractor (A62613)
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
We do NOT accept credit cards as payment. (A64127)
We do NOT accept...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
UNUSED LANDHONOR SPEAR (A64280)
UNUSED LANDHONOR...
