making 3pt impliments compatable with imatch
   / making 3pt impliments compatable with imatch #1
indyjim1
is there a part available to make 3 pt equipment compatable with imatch
I have a CM tiller and several other pieces (seed spreader etc)
I am looking for something to bolt or weld on the equipment ot make it imatch compatable
   / making 3pt impliments compatable with imatch #2
When I had my Imatch I had to modify a couple attachments to work. Usually it just involved adding a top link pin and bushing in a lower location than the original. If you are handy, and especially if you weld, you'll have no trouble. Sometimes its as simple as drilling a couple holes.
   / making 3pt impliments compatable with imatch #3
There is no ready made parts available. Each implement will require a different solution to make it fit. But when you are done you will smile from ear to ear at the pleasure of hooking up a heavy implement with the I-Match.
   / making 3pt impliments compatable with imatch #4
You do not say just what the problem is. To make one of my implements work I had to weld a 2" square tube to each side to build the width and drill the tube for the bottom pins. Another just installed longer bottom pins. Another had to take the A frame off and space it out with pipe spacers. Some work with the hook some with the adapter but like kennyd said just look at it find a game plan and if that does not work look at it some more, my bb is still not right after 3 or 4 tries, finally measured and discovered box was not welded square.
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
12in Backhoe Bucket (A52748)
12in Backhoe...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
Year: 2013 Make: Ford Model: Edge Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 217,869 Plate: (A51694)
Year: 2013 Make...
