Makeing cement
/ Makeing cement
mbjacobs
I guess our figures are very close, so it should be right.
In my area a 5 sack mix is 5 sacks per cu yard- 6 sack mix is 6 sacks per cu yard. for stronger mix they add 20% rock to the load. This is why I use road gravel instead of concrete sand.
With my 1 sack mixer @ 5 sack mix 5 dumps will be one cu yard. when I want alittle heaver mix I will put in 8 buckets instead of 10 per load, this should geat me close to a 6 sack mix, but I have never worked it out on paper, just a guess.
/ Makeing cement #12
DDT
Some yards sell aggregate mix that contains the right proportion of sand and gravel for a concrete mix. You add the appropriate amount of portland cement and water. Crushed stone makes a stronger concrete than does washed smooth gravel. The amount of water added to the mix affects the end strength of the concrete. Some people like a wet mix that flows easy but a thick mix that needs to be rodded and vibrated into the forms yields a stronger end product.
RonL
/ Makeing cement #13
RonL
This is exactly what I did several years ago. The yard had a special pile of sand and agrigate that was pre-measured for mixing of concrete. I paid a little less than $75 bucks for a whole yard (27 cu ft.).
Peter
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
