Makeing cement
/ Makeing cement #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I have a 1 sack mixer and it has mixed alot. The problem is I'm tired of screwing my back up for weeks after a pour (I think this is where wisdom comes in) I use 5 gal. buckets of sand to load the mixer. A bag of portland will fill 2 buckets and 10 buckets of sand makes a 5 sack mix (fine for sidewalks). I am going to build a small combine bin so I can use the loader to fill it. I need to make sure my math is right. I don't have scales so I use volume to get the right mixture.
A bucket is 11" dia x 13" deep. one bucket holds 1235.431 cu in X 10 buckets =12354.31cu in convert to cu ft is 7.149487. Is this right?
Now the bin will hold 7cu ft of sand so I just back the mixer up to the bin and open the gate to fill slowly add water and portland and my back won't get me down.
DDT
/ Makeing cement #3
Doesn't it depend on grain size when converting from cu in to cu ft?
/ Makeing cement #4
Hey guys
Don't forget cement comes in bags and is a powder.
Concrete comes out of a mixer and is the wet stuff.
Just a pet hate from a construction type /w3tcompact/icons/grin.gif
Cheers
/ Makeing cement #5
FWIW, a lot of the strength of concrete is from the aggregate. An all sand mix won't be that stong.
/ Makeing cement #6
Ain't it 3-1? 3 parts sand to 1 part concrete mix?
Helpful hillbilly hint. Toss in a few shovel fulls of gravel. Makes the stuff got much farther! I learned more about the stuff in a week than I want to know.
/ Makeing cement #7
I thought the mix was 1-2-3, 1 part cement, 2 parts sand, and 3 parts gravel. I could be wrong though.
Ed King
/ Makeing cement #8
That's the formula I always heard - but you couldn't prove it by me - mine always comes right out of the truck all wet and ready.
mike
/ Makeing cement #9
I thought we were talking about concrete.
/ Makeing cement #10
OF COURSE ... OF COURSE ... /w3tcompact/icons/blush.gif I was ... what could you possibly think of otherwise ?? /w3tcompact/icons/shocked.gif/w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
mike
/ Makeing cement
mbjacobs
I guess our figures are very close, so it should be right.
In my area a 5 sack mix is 5 sacks per cu yard- 6 sack mix is 6 sacks per cu yard. for stronger mix they add 20% rock to the load. This is why I use road gravel instead of concrete sand.
With my 1 sack mixer @ 5 sack mix 5 dumps will be one cu yard. when I want alittle heaver mix I will put in 8 buckets instead of 10 per load, this should geat me close to a 6 sack mix, but I have never worked it out on paper, just a guess.
/ Makeing cement #12
DDT
Some yards sell aggregate mix that contains the right proportion of sand and gravel for a concrete mix. You add the appropriate amount of portland cement and water. Crushed stone makes a stronger concrete than does washed smooth gravel. The amount of water added to the mix affects the end strength of the concrete. Some people like a wet mix that flows easy but a thick mix that needs to be rodded and vibrated into the forms yields a stronger end product.
RonL
/ Makeing cement #13
RonL
This is exactly what I did several years ago. The yard had a special pile of sand and agrigate that was pre-measured for mixing of concrete. I paid a little less than $75 bucks for a whole yard (27 cu ft.).
Peter
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A65563)
INOP/NON-RUNNING...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
VH4D Wisconsin Engine (A65640)
VH4D Wisconsin...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
