Make Hydraulic line?
/ Make Hydraulic line? #11
Most hydraulic flares in my experience are what are called reverse flare fittings. The male end is down in the socket of what looks like the female part. They are also a double flare which is a special tool that folds it into itself and gives a double wall flare which withstands vibration better. Yes, they are 37 degree also which is not your standard hardware store item. Auto gas lines and brake lines use the same system. Most good hydraulic shops can duplicate the lines much cheaper than buying from the dealer.
Ron
37 degree fittings are not used on automotive. The ISO Flare (Bubble Flare) is 45 degrees and the female seat angle is 96 degrees. The Double Flare is 45 degrees and the inverted seat angle is 42 degrees. The DIN Flare (Mushroom) is 31degrees and the female seat angle is 120 degrees.
/ Make Hydraulic line? #12
But if you want to avoid leaks your best option is ORFS connections.
/ Make Hydraulic line? #13
Go with some rated compression fittings and the proper tubing. Bending tools would be required but they are not expensive.
You'll have to locate a supplier as the local hardware fittings are not up to the pressure ratings required.
[PDF]An Installer's Pocket Guide for Swagelok® Tube Fittings
www.swagelok.com/downloads/webcatalogs/EN/MS-13-151.pdf
innovations in design and manufacture defined by 36 active Swagelok tube fitting patents issued since 1989 . Metric Swagelok Tube Fittings. Metric tube fittings ...
/ Make Hydraulic line? #14
They call those "AN" fittings, from "Army-Navy".
Yes, those are the ones used for automotive hydraulic applications, and (sadly) you guys at DHH don't carry
any adapters. The last time I used an automotive PS pump to power an hydraulic cylinder, I had to buy an
AN adapter, which connected up fine to my JIC hoses.
AN fittings are also 37 degree flare, and can be interchanged with JIC in most industrial applications. However, true AN fittings are made from aluminum and may also be approved for aviation applications. Standard JIC fittings (usually steel or stainless steel) are not approved for aviation.
Just sharing this, because I wasn't sure if your comment was referring to JIC or to the other flare being discussed. Some readers might be new here, and be confused by some of the conflicting information in this thread.
JIC = 37 flare (usually steel, but can sometimes be purchased in brass or stainless steel). Common in most fluid power applications, including farm tractors, forklifts, bucket lifts, car carriers, etc. Male thread on the fitting, female thread on the tube nut or hose end (usually swivels).
AN = 37 flare (aluminum). Common in some automotive applications, usually high performance motorsports, and also aviation. Same thread size and configuration as JIC above, but AN fittings are manufactured to stricter tolerances, which is why they are approved for aviation.
As someone else pointed out, we do not sell AN fittings at DiscountHydraulicHose.com.
/ Make Hydraulic line? #15
So AN fittings are always aluminum? I was disappointed to see the last one I bought was Al, tho the
pressures involved are 1500 psi or less.
I would like to see more adapters available from the more common power steering pump threads (metric) to
JIC-male.
/ Make Hydraulic line? #16
JIC-male.
AN fittings don't have to be aluminum, but most of the time, they are. Check with your supplier if you need another material. Thing is, unless you are working on an aircraft or a piece of military hardware, you probably don't need AN fittings. JIC is specified in most agricultural and industrial applications, and JIC fittings are almost always steel.
To answer your other issue, DiscountHydraulicHose.com carries a number of JIC to metric thread adapters, which you can find here. Metric Steel Hydraulic Fittings
/ Make Hydraulic line? #17
so besides the dealer, where do you usually pickup steel hydraulic lines? I want to run a pair of hard lines from around the FEL control to the front, then put some quick connectors so I can remove the grapple if I want/need to. I'll run hose from my rear remote to the hard lines on the FEL. It would be easier to just run hose all the way up, but that isn't as clean and could potentially get in the way. So any advice on where to procure some steel hydraulic lines would be greatl appreciated.
/ Make Hydraulic line? #18
If you can find a good hydraulic repair service in your area, they should have the hydraulic tubing needed to make up some steel lines. If you have the right tools, you can bend and flare it yourself. If not, they can probably do it for you.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A59230)
1987 International...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
