Rotary Cutter Make and model?
/ Make and model? #1
srodenny
Mitsubishi MT372
Trying to determine make and model of this cutter. It was originally red and I thought it was a Bush Hog. But couldn’t find it on their website. I need a blade bar (a lil bent) and flange nut. I purchased a M30x2 nut, but it was too big . The shaft appears to be 1”. Any help would be appreciated.
/ Make and model? #2
Can you find a number on the blades anywhere? Also, there could be a number on the cutter bar.
/ Make and model?
Yes, the numbers on both blades -
H36
H. 6. 17. SP
/ Make and model?
Should be L36
/ Make and model? #5
H36
H. 6. 17. SP
Perhaps a Titan/Branson mower, discontinued. Only difference was the stump jumper bellypan on these mowers.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.ironcraftco.com/_files/ugd/352071_56261e1d570545919ce916640d71e143.pdf
What is the width of the mower? What is the width, thickness and length of the blade?
/ Make and model?
5’ mower
blades - 25”x3”x1/2” .
Bar is 16”x4”x 1/2”
/ Make and model?
Picture of blade assembly
/ Make and model? #8
It could be a Titan 1105 or a KingKutter. I see all with a disc stumpjumper blade carrier, but could be an earlier mower. Find a blacksmith shop with a hydraulic press that can straighten your blade carrier OR by a belly pan for KingKutter that matches your hole diameter and spline count.
/ Make and model? #9
Blade for KingKutter: 24
/ Make and model?
Ok, thanks for the help. I’ll start there.
/ Make and model?
Ok, I see they have a 12 spline also.
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
Mini rock grapples (A61567)
Mini rock grapples...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
