Rotary Cutter Make and model?
/ Make and model? #1
srodenny
Mitsubishi MT372
Trying to determine make and model of this cutter. It was originally red and I thought it was a Bush Hog. But couldn’t find it on their website. I need a blade bar (a lil bent) and flange nut. I purchased a M30x2 nut, but it was too big . The shaft appears to be 1”. Any help would be appreciated.
/ Make and model? #2
Can you find a number on the blades anywhere? Also, there could be a number on the cutter bar.
/ Make and model?
Yes, the numbers on both blades -
H36
H. 6. 17. SP
/ Make and model?
Should be L36
/ Make and model? #5
H36
H. 6. 17. SP
Perhaps a Titan/Branson mower, discontinued. Only difference was the stump jumper bellypan on these mowers.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.ironcraftco.com/_files/ugd/352071_56261e1d570545919ce916640d71e143.pdf
What is the width of the mower? What is the width, thickness and length of the blade?
/ Make and model?
5’ mower
blades - 25”x3”x1/2” .
Bar is 16”x4”x 1/2”
/ Make and model?
Picture of blade assembly
/ Make and model? #8
It could be a Titan 1105 or a KingKutter. I see all with a disc stumpjumper blade carrier, but could be an earlier mower. Find a blacksmith shop with a hydraulic press that can straighten your blade carrier OR by a belly pan for KingKutter that matches your hole diameter and spline count.
/ Make and model? #9
Blade for KingKutter: 24
/ Make and model?
Ok, thanks for the help. I’ll start there.
/ Make and model?
Ok, I see they have a 12 spline also.
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2019 Komatsu WA380-8 Loader (A64194)
2019 Komatsu...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
