Mahindra tractor wont start
   / Mahindra tractor wont start #1
Camcell
Mahindra Max26XL HST
when i turn ignition on, you can here the glow plugs - but will not run over, no lights on dash.
battery is fine -have cleaned and re-grounded; have checked safety switches; can jump start at solenoid but does not keep running.
have power to ignition, no power to fuel pump, no power to stop solenoid.
followed wiring and cleaning connectors full of dust and was able to get lights on dash turn on briefly
Seems like a kill switch issue, what other that the 5 safety switches might this be.
Thanks in advance...
   / Mahindra tractor wont start #2
?PTO?
   / Mahindra tractor wont start #3
FWIW, I had a Mahindra with a PTO safety switch under the operator's platform. That switch would prevent starting every time enough debris built up inside the switch housing even though it didn't look bad from the outside.
   / Mahindra tractor wont start #4
My 3510 has to have both pto switches off and clutch in to start
thanks all, no not a safety switch.
if safety switch I still would have dash lights.
   / Mahindra tractor wont start #6
Look at the fusable link at the + battery terminal. Then move on to the fuse panel. I would use a volt meter or test light.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2010 John Deere 8320R Tractor (A59814)
2010 John Deere...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
