Mahindra tractor wont start
   / Mahindra tractor wont start #1
Camcell
Mahindra Max26XL HST
when i turn ignition on, you can here the glow plugs - but will not run over, no lights on dash.
battery is fine -have cleaned and re-grounded; have checked safety switches; can jump start at solenoid but does not keep running.
have power to ignition, no power to fuel pump, no power to stop solenoid.
followed wiring and cleaning connectors full of dust and was able to get lights on dash turn on briefly
Seems like a kill switch issue, what other that the 5 safety switches might this be.
Thanks in advance...
   / Mahindra tractor wont start #2
?PTO?
   / Mahindra tractor wont start #3
FWIW, I had a Mahindra with a PTO safety switch under the operator's platform. That switch would prevent starting every time enough debris built up inside the switch housing even though it didn't look bad from the outside.
   / Mahindra tractor wont start #4
My 3510 has to have both pto switches off and clutch in to start
thanks all, no not a safety switch.
if safety switch I still would have dash lights.
   / Mahindra tractor wont start #6
Look at the fusable link at the + battery terminal. Then move on to the fuse panel. I would use a volt meter or test light.
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2014 HYUNDAI Veloster Hatchback (A56859)
2014 HYUNDAI...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
2019 Ford F-550 4x4 ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
GRAIN AUGER (A52708)
