Mahindra mpower 85 problems
   / Mahindra mpower 85 problems
I was told by the dealership to buy a Radiator Genie and use the water instrument first to clean radiator and coils and then blow it out with air. I did it in the morning and baled hay all day and the tractor ran cool and A/C blew cold air. I did the same thing the next day with the same results. Thanks to everyone for y'alls help and get yourself a Radiator Genie.
   / Mahindra mpower 85 problems #12
I use the radiator Genie as well. Need to clean out AC coil every time mowing tall stuff and very dusty conditions.
Just part of PM like checking oil.
AC will freeze me out most of the time. The AC coil will plugging up quick if not kept clean.
   / Mahindra mpower 85 problems #13
Make sure your 3 pt lift is in neutral. I had this problem w my 65 hp.
   / Mahindra mpower 85 problems #14
that's not the 3point lift it was your rear spool remotes... it has a detent and can stay engaged
   / Mahindra mpower 85 problems #15
I have mpower 85p and I use the Radiator Genie with compressed air on it. Works real good. Also I cut out universal foam filter like for the house window units and hot glued them on the intake vents. Now I just have to blow them out each day when baling and only open the hood and blow out screens and radiator, condenser and intercooler about every month. I also replace these filters every year. They get torn up over time. Hope this helps I know it is an old thread.
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Killbros 1135 Grain Cart (A59814)
Killbros 1135...
