Mahindra Max 26 FEL, BH used price check
   / Mahindra Max 26 FEL, BH used price check #1
mdogs444
chardon, oh
Ford 9n
Hello All -
I have enjoyed the wealth of knowledge here on the forums in helping me narrow down my choice of tractor for my new property. I have recently moved onto 8 acres, wooded, with only about 2.5-3 acres that require maint. I'll be mowing around a pond with some hills that is rough cut grass, using the tractor to haul firewood up to the barn for splitting, basic landscaping, snow maint in NE Ohio (snowbelt), etc.
I have settled on a Max 26 and have been looking at new and used in the area.
I found a deal on a used model 2014 with 300 hours, loader, backhoe and shuttle shift for about $14500. Its not original owner - it was a trade in, but since its still under warranty I think its safe. It looks meticulous with the only minimal scratches being on the buckets from light use.
Do you guys find this to be a good deal, and if so, is there anything I should be on the look out for when checking it out? Its about a 4 hr drive, so I want to get all my ducks in a row first.
Thanks
Michael
   / Mahindra Max 26 FEL, BH used price check #2
Hello All -
Thanks
Michael
That all depends on what the new price is but that doesn't sound like a bad deal to me right off the bat especially with a backhoe. Just make sure it's a Mahindra hoe and not one of those 3pt things.
Its a full mahindra setup, not an aftermarket backhoe. I have about 12 pictures of the unit and confirmed running, and that everything works - with exception of the 3pt. Since the loader is attached, i will need to have him remove that and verify the 3point is working as expected.
I priced them out new in my area and i was quoted about $22k for a new Max 26, FEL, backhoe,60" finishing mower, and blade. Counting tax, its around $23,500
   / Mahindra Max 26 FEL, BH used price check #4
He'd have to pull the backhoe to check the 3pt, not the front end loader. It's not a big deal but a dolly does help so I made one to ease the task for myself.
Yes, thats what i meant. Typo...with out proofreading :)
   / Mahindra Max 26 FEL, BH used price check #6
Hello All -
Thanks
Michael
Mike
If that's the tractor you want, Great deal! Scoop it up.
   / Mahindra Max 26 FEL, BH used price check #7
I recently was looking at emax25 and max26, new. The max was out out of budget. What you found is broken in and a good deal.
Check for the 50hr service!
Just to CYA offer $500 less but snare it anyway.
-R9
   / Mahindra Max 26 FEL, BH used price check #8
Good buy:thumbsup:
   / Mahindra Max 26 FEL, BH used price check #9
I am pretty sure this is the tractor you are looking at
Mahindra Max 26 XL tractor with loader and backhoe
I called and there are a few things that knocked this pretty far down my list.... Its not a quick change bucket, and I want to add a grapple and will probably be swapping quite a bit. Its the shuttle shift and I will be doing a lot in my woods, so a lot of loader work in small spaces, not very great for a shuttle shift. It really wont have much warranty left. And I have a friend to bought a tractor from this guy that ended up having all sorts of issues as soon as he got it home... I don't know the whole story, but it was enough for me to question a guy that frequently buys and sells used tractors as a "side business"
   / Mahindra Max 26 FEL, BH used price check #10
Shuttle on the Max shifts like a Mazda Miata compared to most tractor manual gear boxes. I would not want the 2 Speed HST for my use, and that involves a lot of loader work. I really like the 8 x 8 shuttle.
You can get a QA plate, just figure $750 and take that off your offering price.
Strong little nice tractor for the woods.
If you have a good local dealer, that is the real question with Mahindra.
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
