Mahindra Max 26 FEL, BH used price check
   / Mahindra Max 26 FEL, BH used price check #1
mdogs444
chardon, oh
Ford 9n
Hello All -
I have enjoyed the wealth of knowledge here on the forums in helping me narrow down my choice of tractor for my new property. I have recently moved onto 8 acres, wooded, with only about 2.5-3 acres that require maint. I'll be mowing around a pond with some hills that is rough cut grass, using the tractor to haul firewood up to the barn for splitting, basic landscaping, snow maint in NE Ohio (snowbelt), etc.
I have settled on a Max 26 and have been looking at new and used in the area.
I found a deal on a used model 2014 with 300 hours, loader, backhoe and shuttle shift for about $14500. Its not original owner - it was a trade in, but since its still under warranty I think its safe. It looks meticulous with the only minimal scratches being on the buckets from light use.
Do you guys find this to be a good deal, and if so, is there anything I should be on the look out for when checking it out? Its about a 4 hr drive, so I want to get all my ducks in a row first.
Thanks
Michael
   / Mahindra Max 26 FEL, BH used price check #2
Hello All -
Thanks
Michael
That all depends on what the new price is but that doesn't sound like a bad deal to me right off the bat especially with a backhoe. Just make sure it's a Mahindra hoe and not one of those 3pt things.
Its a full mahindra setup, not an aftermarket backhoe. I have about 12 pictures of the unit and confirmed running, and that everything works - with exception of the 3pt. Since the loader is attached, i will need to have him remove that and verify the 3point is working as expected.
I priced them out new in my area and i was quoted about $22k for a new Max 26, FEL, backhoe,60" finishing mower, and blade. Counting tax, its around $23,500
   / Mahindra Max 26 FEL, BH used price check #4
He'd have to pull the backhoe to check the 3pt, not the front end loader. It's not a big deal but a dolly does help so I made one to ease the task for myself.
Yes, thats what i meant. Typo...with out proofreading :)
   / Mahindra Max 26 FEL, BH used price check #6
Hello All -
Thanks
Michael
Mike
If that's the tractor you want, Great deal! Scoop it up.
   / Mahindra Max 26 FEL, BH used price check #7
I recently was looking at emax25 and max26, new. The max was out out of budget. What you found is broken in and a good deal.
Check for the 50hr service!
Just to CYA offer $500 less but snare it anyway.
-R9
   / Mahindra Max 26 FEL, BH used price check #8
Good buy:thumbsup:
   / Mahindra Max 26 FEL, BH used price check #9
I am pretty sure this is the tractor you are looking at
Mahindra Max 26 XL tractor with loader and backhoe
I called and there are a few things that knocked this pretty far down my list.... Its not a quick change bucket, and I want to add a grapple and will probably be swapping quite a bit. Its the shuttle shift and I will be doing a lot in my woods, so a lot of loader work in small spaces, not very great for a shuttle shift. It really wont have much warranty left. And I have a friend to bought a tractor from this guy that ended up having all sorts of issues as soon as he got it home... I don't know the whole story, but it was enough for me to question a guy that frequently buys and sells used tractors as a "side business"
   / Mahindra Max 26 FEL, BH used price check #10
Shuttle on the Max shifts like a Mazda Miata compared to most tractor manual gear boxes. I would not want the 2 Speed HST for my use, and that involves a lot of loader work. I really like the 8 x 8 shuttle.
You can get a QA plate, just figure $750 and take that off your offering price.
Strong little nice tractor for the woods.
If you have a good local dealer, that is the real question with Mahindra.
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
