Mahindra common issues
/ Mahindra common issues #1
chevyman09
JD 5300
Currently looing at purching one of the following -2014 mahindras 6110 800hrs and a 5010 400hrs and a 2021 6075 115hrs. All have cabs. I can't seem to find much info on them. Looking for opinions on them especially if you own or have owned one. Both dealers are about 2hrs from me and have been around awhile.
the 6075 while larger then what i need the price is pretty good to not consider.
It will be used on 80 acres shredding, brush/tree clearing food plots fence line clearing and maybe even some services like pasture cutting and dirt moving if I ever find free time to start a side gig to make extra money
/ Mahindra common issues #2
I have a 4510. My difficulties with it has been very long delays in getting many repair parts. Sometime months. My machine was built in 2004. If I was a full time farmer this would be real trouble. As is I can use another tractor and equipment.
It may be entirely different with your models.
What kind of parts? Other than that how has the tractor treated you
/ Mahindra common issues #4
Usually just simple parts but needed. I needed a door glass once. It came in quickly but a gasket as I recall took months. Some other small but needed part but I do not recall now. Fortunately both these were during the winter so no real down time for me.
It took awhile but I finally have it where it works for me. Mostly overheating issues. The original battery placement blocked much incoming air. Then added an auxillary fan. Finally got it to run cool by taking off both engine side panels. If it was used in a true farm application it may have been OK but I get in tall weedy areas and the debris would clog up the radiator and have to be blown out often. Any tractor may have had those issues.
The door glass is an issue. They are "frail". One was broken before I purchased the 2004 in 2008. Two have broken with me. Heavy branches did it. In a clean field no problem. A company does sell some high grade covers now to protect tractor glass.
The problem with removing the side panels it exposed the factory fuel filter. Ruined several of those before I relocated under the hood in a protected area.
/ Mahindra common issues #5
Being 2 hours from a dealer can be very inconvenient if you ever need to take the tractor to the dealer for service. I would prefer having a good dealer closer if that is an option for you.
/ Mahindra common issues #6
ICurrently looing at purching one of the following -2014 mahindras 6110 800hrs and a 5010 400hrs and a 2021 6075 115hrs. All have cabs. I can't seem to find much info on them. Looking for opinions on them especially if you own or have owned one. Both dealers are about 2hrs from me and have been around awhile.
I sell Mahindras and Im very sorry to say that no one can go by anything anyone says about their tractors as to their efficacy.
It doesn’t work that way. It’s more of a chance thing that crossing your fingers would work just as well.
One should not be concerned about what no one on this planet can know…..telling the future. I have seen both elation and horror with identical models throughout the industry.
That being said, the newer 5145 and 5155 have over 100 improvements over the tractors you mention.
Haven’t seen any of these on the lot with a cab however.
I’d listen to Too Many. Pick a dealer before a brand.
Those tractors you mention have too few hrs to be on the market. Why? Were those lemons by any chance. Are you buying a headache?
Get the serial numbers and start exploring their service history.
/ Mahindra common issues #7
Buy the newer one,
Parts are no harder to get than any other brand.
I have never had issue getting parts since buying my first Mahindra in 2003. Low hour machine should not be worked hard enough to start breaking things.
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
(2) 27x32 CIH Rims (A65640)
(2) 27x32 CIH Rims...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
72" JCT TILLER (A62613)
72" JCT TILLER...
