mahindra backhoe problems
/ mahindra backhoe problems #1
juck
grants pass OR
mahindra 2615
I have a 2615 HST with a backhoe. When I ues any lever to the hoe it hesitates for about 5 to 10 seconds then moves the cylinder very slowly for another few seconds then operates at the correct speed.power seems ok. I changed hydro filter but no change.I noticed foamy looking oil when I pulled the filter. Fluid level is correct. I ran all the cylinders through a full cycle multiple times to purge air. Thamks for any help
/ mahindra backhoe problems #2
:welcome:Sorry I cannot help you with your question I do not have a BH but I am sure others will chime in with some help. Good luck.:thumbsup:
/ mahindra backhoe problems #3
might be junk in the spool, is it new?
/ mahindra backhoe problems #4
All your quick disconnects fully seated? A partial will restrict hyd flow substantially.
Jim
No its not new.It worked fine one day,the next it started acting up.If it was junk in the spool would it affect all cylinders and the speed change through the stroke?
Yes, I checked all 3 quick connectors. Any other thoughts?
/ mahindra backhoe problems #7
You said foamy, is the oil milky colored?
/ mahindra backhoe problems #8
juck, welcome to TBN. I have the same tractor and backhoe as you. Upon checking the owner's manual, here is what it says about slow operation of machine, and possible problems, (lack of power) all cylinders:
Low oil supply in reservoir - fill to proper level
Oil viscosity too heavy, or oil is not at operating temperature - use recommended hydraulic fluid - Run machine until oil reaches operating temperature.
Insufficient pumping - advance engine throttle.
Excessive back pressure - Relieve condition. Restriction may be from outlet to reservoir.
Relief valve setting in backhoe control valve too low or defective - Relief pressure will have to be checked and corrections made. Relief valve may need cleaning and overhauling, or entire cartridge must be replaced.
Your comment about the foamy looking oil concerns me. I've not seen this in my hydraulic system. If I were you, I'd call Rogue Valley Farm Equipment, the S. Oregon Mahindra dealer. Ask for Rick, my go to guy for technical help. 541 826-8500
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
213141 (A64276)
213141 (A64276)
