Mahindra 6525 small issue?
   / Mahindra 6525 small issue? #1
Mooster
La Feria, Texas
JD LA135
Howdy all,
Finally pulled the trigger on a 2009 Mahindra 6525. Enjoying it so far. Quick question. When going from N to H or L range it grinds going in. Is that normal or is maybe idle too high? How would I adjust it? Any help would be greatly appreciated.
Thnx,
Mooster
Howdy all,
Thnx,
Mooster
I checked it out again this morning and the issue is only to high range not low. Is there anything I can check or adjust?
Thanx again,
Mooster
   / Mahindra 6525 small issue? #3
I don't think you are supposed to be able to shift the High/Medium/Low shifter while moving.
   / Mahindra 6525 small issue? #4
Is it a mechanical gear change ? Maybe your clutch travel needs adjusting. I had similar symptoms on both my old MF65 and my Jinma when the clutch pedal needed adjusting to give proper clearances.
I figured it out. Yes, its mechanical and no, not while moving.
if I tap the throttle while shifting it goes right in or as its starting ill pop it into high and it goes right in.
Thanx
Moose
   / Mahindra 6525 small issue? #6
Thanx
Moose
That happens sometimes with my 5525 since the tranny is only partially synchronized. I do the same thing with the throttle as you. Like driving my first car---a 1955 Ford 2-door with a fairly worn stick tranny.
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2019...
BOX OF BINDERS & MISC (A52708)
BOX OF BINDERS &...
UNUSED FUTURE 32"...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
