Mahindra 6525 small issue?
/ Mahindra 6525 small issue? #1
Mooster
La Feria, Texas
JD LA135
Howdy all,
Finally pulled the trigger on a 2009 Mahindra 6525. Enjoying it so far. Quick question. When going from N to H or L range it grinds going in. Is that normal or is maybe idle too high? How would I adjust it? Any help would be greatly appreciated.
Thnx,
Mooster
Howdy all,
Thnx,
Mooster
I checked it out again this morning and the issue is only to high range not low. Is there anything I can check or adjust?
Thanx again,
Mooster
/ Mahindra 6525 small issue? #3
I don't think you are supposed to be able to shift the High/Medium/Low shifter while moving.
/ Mahindra 6525 small issue? #4
Is it a mechanical gear change ? Maybe your clutch travel needs adjusting. I had similar symptoms on both my old MF65 and my Jinma when the clutch pedal needed adjusting to give proper clearances.
I figured it out. Yes, its mechanical and no, not while moving.
if I tap the throttle while shifting it goes right in or as its starting ill pop it into high and it goes right in.
Thanx
Moose
/ Mahindra 6525 small issue? #6
Thanx
Moose
That happens sometimes with my 5525 since the tranny is only partially synchronized. I do the same thing with the throttle as you. Like driving my first car---a 1955 Ford 2-door with a fairly worn stick tranny.
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
