mahindra 6500
   / mahindra 6500 #1
tom dunlap
davenport, ok
mahindra 6500
My Mahindra 4wd 6500 starts to miss or cut out "spuddering" after 20-30 minutes run time. Any thoughts on how to address?
Thank you,
Tom
   / mahindra 6500 #2
There is a fuel/timing advance that automatically times out about then. Are you running it easy, or with a good load?
larry
   / mahindra 6500
Larry
Under a load. typically while brush hogging
Thanks
Tom
   / mahindra 6500 #4
Welcome. ... Its probably the fuel filter then. Normally the power goes a little weak before it starts to cut out. Often when the load is removed it will idle just fine and when turned off for a short time it will work again for a little while. If this fits replace the filter.
   / mahindra 6500 #5
All of the above and could also be bad fuel , as a friend was having a similar problem as you and it was water in his fuel .
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A55973)
2015 Peterbilt 348...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
