mahindra 6500
   / mahindra 6500 #1
tom dunlap
davenport, ok
mahindra 6500
My Mahindra 4wd 6500 starts to miss or cut out "spuddering" after 20-30 minutes run time. Any thoughts on how to address?
Thank you,
Tom
   / mahindra 6500 #2
There is a fuel/timing advance that automatically times out about then. Are you running it easy, or with a good load?
larry
   / mahindra 6500
Larry
Under a load. typically while brush hogging
Thanks
Tom
   / mahindra 6500 #4
Welcome. ... Its probably the fuel filter then. Normally the power goes a little weak before it starts to cut out. Often when the load is removed it will idle just fine and when turned off for a short time it will work again for a little while. If this fits replace the filter.
   / mahindra 6500 #5
All of the above and could also be bad fuel , as a friend was having a similar problem as you and it was water in his fuel .
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
SKID STEER ATTACHMENT ROCK SIFTER WITH BUCKET (A58214)
SKID STEER...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
