mahindra 6500
   / mahindra 6500 #1
tom dunlap
davenport, ok
mahindra 6500
My Mahindra 4wd 6500 starts to miss or cut out "spuddering" after 20-30 minutes run time. Any thoughts on how to address?
Thank you,
Tom
   / mahindra 6500 #2
There is a fuel/timing advance that automatically times out about then. Are you running it easy, or with a good load?
larry
   / mahindra 6500
Larry
Under a load. typically while brush hogging
Thanks
Tom
   / mahindra 6500 #4
Welcome. ... Its probably the fuel filter then. Normally the power goes a little weak before it starts to cut out. Often when the load is removed it will idle just fine and when turned off for a short time it will work again for a little while. If this fits replace the filter.
   / mahindra 6500 #5
All of the above and could also be bad fuel , as a friend was having a similar problem as you and it was water in his fuel .
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
1998 JOHN DEERE 310E BACKHOE (A51242)
1998 JOHN DEERE...
