Mahindra 6075 only goes in reverse
   / Mahindra 6075 only goes in reverse #11
Looking at your pic, you may be on the top fuse box because that’s where the fuse puller is as labeled . Unless the 75 is different from the 65 we have
The bottom fuse box on a cabbed model is at your feet. Thats where the reset fuse should be.
   / Mahindra 6075 only goes in reverse #12
I have a 2018 Mahindra 6065. I had a similar problem, it would only move in reverse no matter what I did with the power shuttle lever. I had a small hydraulic leak in a fitting and it started working again after topping up the fluid.
The 6000 series also had an issue with the transmission housing being milled incorrectly, which caused hard shifting. I had mine fixed under warranty service.
   / Mahindra 6075 only goes in reverse #13
So when I got back, I found that the 65 we had was picked up.
It was sitting on our lot for 3 months and the week I'm gone, it gets sold.
I am very sorry not to be able to make this comparison for you as to location of re-set fuse.
On the 65, it was at the floor mounted box and the third fuse from the left labeled "re-set"
The 75 could be in a different location.
Again, my apologies.
More info coming soon! (A55851)
More info coming...
2020 FREIGHTLINER PT126SLP TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2014 Volvo L60G Articulated Wheel Loader (A56857)
2014 Volvo L60G...
WINCH CABLE DRUM (A58216)
WINCH CABLE DRUM...
