Mahindra 6075 only goes in reverse
   / Mahindra 6075 only goes in reverse #11
Looking at your pic, you may be on the top fuse box because that’s where the fuse puller is as labeled . Unless the 75 is different from the 65 we have
The bottom fuse box on a cabbed model is at your feet. Thats where the reset fuse should be.
   / Mahindra 6075 only goes in reverse #12
I have a 2018 Mahindra 6065. I had a similar problem, it would only move in reverse no matter what I did with the power shuttle lever. I had a small hydraulic leak in a fitting and it started working again after topping up the fluid.
The 6000 series also had an issue with the transmission housing being milled incorrectly, which caused hard shifting. I had mine fixed under warranty service.
   / Mahindra 6075 only goes in reverse #13
So when I got back, I found that the 65 we had was picked up.
It was sitting on our lot for 3 months and the week I'm gone, it gets sold.
I am very sorry not to be able to make this comparison for you as to location of re-set fuse.
On the 65, it was at the floor mounted box and the third fuse from the left labeled "re-set"
The 75 could be in a different location.
Again, my apologies.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
JOHN DEERE 469 BALER (A58216)
JOHN DEERE 469...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
