Mahindra 4500 wont go into 1,2, or R
   / Mahindra 4500 wont go into 1,2, or R #1
cowpatty
Oklahoma
TYM 454; Ford LGT 14D
I need help!! My Mahindra 4500 2wd will not go into 1st, 2nd, or reverse. Third and fourth work as they should as does the hi-lo selector. Any insight on what could be the problem?
   / Mahindra 4500 wont go into 1,2, or R #2
Is there a grinding noise when you try for 1, 2, or R?
How's the transmission fluid level?
Clutch adjustment may fix this?
When is the last time you greased the throw out bearing? Doubt this is the problem but good idea to give it a squeeze of grease.
Fluid levels are ok. When I try for one of those gears I can pull it over but it won't slide up or down into gear
   / Mahindra 4500 wont go into 1,2, or R #4
Clutch adjustment.
Also grease the throw out bearing.
Why would third and fourth be fine? Would that cause all gears to bind up?
   / Mahindra 4500 wont go into 1,2, or R #6
Cluth isn't travelling far enough to engage all gears because of slop.
Tighten it up and try it out.
Trying to bounce enough ideas around until something works.
   / Mahindra 4500 wont go into 1,2, or R #7
Maybe the shifter linkage is buggered and binding?
377780 (A48837)
377780 (A48837)
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2022 KUBOTA SVL97-2 SKID STEER (A51242)
2022 KUBOTA...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
