Mahindra 4500 wont go into 1,2, or R
   / Mahindra 4500 wont go into 1,2, or R #1
cowpatty
Oklahoma
TYM 454; Ford LGT 14D
I need help!! My Mahindra 4500 2wd will not go into 1st, 2nd, or reverse. Third and fourth work as they should as does the hi-lo selector. Any insight on what could be the problem?
   / Mahindra 4500 wont go into 1,2, or R #2
Is there a grinding noise when you try for 1, 2, or R?
How's the transmission fluid level?
Clutch adjustment may fix this?
When is the last time you greased the throw out bearing? Doubt this is the problem but good idea to give it a squeeze of grease.
Fluid levels are ok. When I try for one of those gears I can pull it over but it won't slide up or down into gear
   / Mahindra 4500 wont go into 1,2, or R #4
Clutch adjustment.
Also grease the throw out bearing.
Why would third and fourth be fine? Would that cause all gears to bind up?
   / Mahindra 4500 wont go into 1,2, or R #6
Cluth isn't travelling far enough to engage all gears because of slop.
Tighten it up and try it out.
Trying to bounce enough ideas around until something works.
   / Mahindra 4500 wont go into 1,2, or R #7
Maybe the shifter linkage is buggered and binding?
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2018 Chevrolet Malibu (A50324)
2018 Chevrolet...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
