Mahindra 3505 Di. Clutch problem
   / Mahindra 3505 Di. Clutch problem #1
Laylo2013
2004 Mahindra 3505 Di
Went to adjust clutch on mahindra 3505 di.
Lossened 2 bolts turned the adjuster 1/4 inch completely lost the clutch. Tractor has a duel clutch system. I'm doing something wrong and don't know what it is. The adjuster rod would only turn one way counter clockwise and only 1/4 inch. Anyhelp would be much appreciated.
   / Mahindra 3505 Di. Clutch problem #2
Did you unscrew it in the housing?
Should have some kind of stop built in?
There is an inspection plate I dropped it make sure it was working. For some reason the shaft wouldn't move. Hit with penatraiting oil last night in the am it had movement.
I was using the tractor the clutch wouldn't do anything. It's unfrozen. I've greased everything it's working fine.
   / Mahindra 3505 Di. Clutch problem #4
Glad you got it figured out.....but I can't figure out what you're saying >;)
   / Mahindra 3505 Di. Clutch problem #5
I broke a pressure plate spring in 3510 and clutch wouldn’t disengage from pressure plate .
I could feel the 2 springs working but the broke one keep it engaged.
Caused by riding the clutch doing loader work.
   / Mahindra 3505 Di. Clutch problem #6
I have a 5005 and have read that the clutch may stick if left idle for a week or 2. I’ve had it happen and now I secure the clutch in the engaged position after use with a cinch strap.
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
John Deere 8R 250 (A50123)
John Deere 8R 250...
2023 JACTO ARBUS-1000 LOT NUMBER 65 (A53084)
2023 JACTO...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
