Mahindra 3316 front axle oil level
   / Mahindra 3316 front axle oil level #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
I am confused about how to check the oil level . In my operators manual there is a picture of an oil level plug on the left front of the axle . I removed the plug and no oil came out . There are also oil level plugs located on the rear of both gear cases that I removed and oil did come out . Is the oil level plug in the front the one to check the oil level or the ones on gear cases ?
   / Mahindra 3316 front axle oil level #2
You want to check the oil level for the front axle in three places:
1: the plug facing front in the axle tube
2 & 3: each side near the front wheels there is a plug facing the rear top of the knuckle housings
So I guess the oil level plug facing the front is low on oil if no oil comes out there ?
   / Mahindra 3316 front axle oil level #5
Make sure to check the tightness of the bolts that hold your cases together. Mine had right side bolts come loose. Now I check them every time I check the loader mounting bolts and I added Loctite.
Thanks . I will check mine also .
Caterpillar CB-54 XW (A50120)
Caterpillar CB-54...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
Case-IH 370 Steiger (A50120)
Case-IH 370...
Bobcat 753 Skidloader (AS IS) (A50774)
Bobcat 753...
Suzuki King Quad ATV (A50515)
Suzuki King Quad...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
