Mahindra 3316 front axle oil level
   / Mahindra 3316 front axle oil level #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
I am confused about how to check the oil level . In my operators manual there is a picture of an oil level plug on the left front of the axle . I removed the plug and no oil came out . There are also oil level plugs located on the rear of both gear cases that I removed and oil did come out . Is the oil level plug in the front the one to check the oil level or the ones on gear cases ?
   / Mahindra 3316 front axle oil level #2
You want to check the oil level for the front axle in three places:
1: the plug facing front in the axle tube
2 & 3: each side near the front wheels there is a plug facing the rear top of the knuckle housings
So I guess the oil level plug facing the front is low on oil if no oil comes out there ?
   / Mahindra 3316 front axle oil level #5
Make sure to check the tightness of the bolts that hold your cases together. Mine had right side bolts come loose. Now I check them every time I check the loader mounting bolts and I added Loctite.
Thanks . I will check mine also .
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
