Mahindra 3316 front axle oil level
   / Mahindra 3316 front axle oil level #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
I am confused about how to check the oil level . In my operators manual there is a picture of an oil level plug on the left front of the axle . I removed the plug and no oil came out . There are also oil level plugs located on the rear of both gear cases that I removed and oil did come out . Is the oil level plug in the front the one to check the oil level or the ones on gear cases ?
   / Mahindra 3316 front axle oil level #2
You want to check the oil level for the front axle in three places:
1: the plug facing front in the axle tube
2 & 3: each side near the front wheels there is a plug facing the rear top of the knuckle housings
So I guess the oil level plug facing the front is low on oil if no oil comes out there ?
   / Mahindra 3316 front axle oil level #5
Make sure to check the tightness of the bolts that hold your cases together. Mine had right side bolts come loose. Now I check them every time I check the loader mounting bolts and I added Loctite.
Thanks . I will check mine also .
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2004 Jeep Wrangler Rubicon 4x4 SUV (A48082)
2004 Jeep Wrangler...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
Headache Rack (A50860)
71050 (A49346)
71050 (A49346)
2018 Dodge RAM 3500 Truck W/Dump Bed (A50860)
2018 Dodge RAM...
