Its good that you pressurized it again. Maybe the grease will penetrate as the pivot works during use. It seems to me that there must be an internal flow path that is blocked - perhaps by misalignment of a hole in the pivot bushing. I would want that assessed and corrected.So I tried greasing the fitting at the axle pivot with the wheels off the ground. Same situation - wouldn't take any grease. I screwed the grease fitting off and grease shot out, clearly under pressure. Same situation as yesterday. I put the fitting back on and pressurized it again. I was expecting grease to come out from somewhere if everything was working properly.
I believe somewhat common practice is to send out a mechanic for simple stuff - push for that.I'm going to be really distraught if I have to carry this thing back before the 50hour service. Granted, I planned to do the 50 hour service myself..
So you guys are confirming that grease should be flowing through the pivot?
I looked in the manual for the tire pressure guidelines and can't find them. One page says to refer to page XX for tire pressures but they aren't on that page. Anyone know where I can find them or what they are? Also, if I fluid fill the tires to 75%, should the pressure be changed?
For your tire pressure chart, look under the pneumatic tire section in your manual, there's a small chart that will give you the Ag & Industrial max inflation, in the 4540 manual it's on page 56.
Good question. It should start to act normal very quickly if its really alright.I actually filled the tires yesterday. I went with straight water for the time being, I plan to go back and add antifreeze or other at some point although I'm not sure it is entirely required where I live.
I just called the main hub for the series of dealerships I got the tractor from. I spoke with a tech, he said that the axle pivot lubrication point not freely flowing grease shouldn't be a problem, that the factory lubrication is there, and is being more difficult to push out the way than the other points. He said that if it is taking grease and is under pressure, then it should be fine. Just to watch it.
I asked what to watch for as my #1 concern is wearing out the pivot which would be an expensive fix. He said that there likely wasn't enough pressure to push out the factory grease, or that the link may be tighter than usual from the factory and not worn in. He said none of this would hurt anything.
I wrote all this down, hopefully he is right.
Loving the tractor so far. I've got some minor gripes but they are related to ergonomics. Massive power compared to what I'm used to (1526). I was wondering how noticeable it would be. Nearly doubling the HP on a similarly weighted machine makes a big difference.. lol
I haven't run an implement that uses the PTO although I did do some dragging with a scraper blade. I was really shocked at how much slip I had in the sandy field but weighting the tires seems to have helped significantly - I don't even notice the slip after having filled all the tires to 75%.
You dont want to slip the clutch to start. Try to use a low enuf start gear so you can just let it out fairly quickly.Any tips on how to lengthen the life of the clutch? The engagement window is so small I am effectively "dumping" it most of the time. I know to not ride the clutch partially engaged but is the goal with a tractor to get off the clutch as quickly as possible or to ease it out slowly each time?
You are breaking the #1 rule when using a loader!Since you guys like pics..
First hour with the machine. Digging out a little trench for drainage. Can't wait to try out the toothbar. Supposed to be here late this week.
First big load of dirt I picked up. Scared the mess out of me. I started backing up and the front left wheel dipped about 4". Rear right tire came up off the ground. Absolute panic for a moment there.
Had to see how far the wheel came up relative to what I felt on the machine. Since I filled the tires I've had larger loads in the bucket with no issue.
10 hours in. Raking up dead corn and leveling out what will be our yard.
