Mahindra 2545 on sand
   / Mahindra 2545 on sand #101
Valve and fittings come in today, I've been thinking about ways to fund a grapple purchase since I literally don't have a reason to buy one other than to clean up a bunch of dead trees at my mom's property. Come to find out, she was just quoted $5500 dollars to clear 15 dead trees, not including stump grinding. My buddy offered to spend a weekend helping me out and it looks like she is going to reimburse me the cost of the grapple if I get rid of the 15 trees for her. In this case I would actually get a good grapple (some of the trees are rather large).
I went ahead and told her it would be between $1500 and $2500 for a grapple after referencing everythingattachments. Anyone have any input on which grapple would be best for the 2545? It comes with a 66" bucket, I'm not sure if it makes sense to match the OEM bucket width or go more narrow. Also, I'm not sure if it would make more sense to get the wicked root grapple V2.0 or the wicked root rake. ]
pripyat,
See posts in this thread. Best general use for the $ is MTL... $999 to your door. You will find all sorts of posts on here on widths. I chose 60" with dual lid.
https://www.tractorbynet.com/forums/century-branson/409032-best-reasonably-priced-grapple-2.html
I didn't realize that these things came without the quick attach. The 1526 has it too. I just wish the bucket didn't make so much racket when I hit bumps in high range.
It really is insane what the price difference is between the MTL and EA. I did some reading on the MTL's but I was turned off on how little information is out there regarding exact unit weight and quality of materials. I'm on the upper end of the HP range of those units. Also, I really don't care to have separate closing clamps. Doesn't seem like it would be useful for what I'm using it for. My worry is that if I go up to a small tree and try to pull it up while engaging only two tines, will it bend the grapple? I feel it would be a lot less likely to bend the EA considering the type of steel used. IDK though. If it were all my money I'd likely just get the MTL. Since I've got someone picking up most or all of the tab, I may splurge and get the EA.
   / Mahindra 2545 on sand #103
Maybe QA is standard these days? Where is the bucket noise coming from? Is it loosely held? Pin adjustment?
I hope its not a dimensional problem with the QA. That would affect all correctly made implements. If its the bucket at fault you may need to weld in some shims on the bucket lower flange. . . . altho that could be a Mahindra responsibility.
The assembly must be secure or the loader can be damaged.​
   / Mahindra 2545 on sand #104
I have more HP and loader than you and mine is fine. I believe there are others on here that use it with the 45-55hp range.
Each has there own opinion on the single/dual lid option though. I can tell you when I grab into a group of trees/branches its nice to have ability for it to close on a large piece while continuing on something smaller right beside it.
Granted, if I were using YOUR money instead of mine, I might step up to a unit with AR400 steel. :laughing:
Wait, so when i'm back dragging the loader shouldnt have any play? I've never messed with the quick attach stuff. When I hit a big bump or dip the loader rotates and makes one heck of a racket from the jostle.
To clarify, if I start back dragging with the loader pointed down at 45 degrees, it will tilt up maybe 15 degrees or so before it catches.
   / Mahindra 2545 on sand #106
Oops. Sorry - lost track of all that was happening.
Check ALL structural bolting on your tractor. Do the loader and wheel lugs right away - before doing anything else. My loader arrived "loose". I noticed some motion but figured it was flex in the long elements of the large to me loader as well as slop in the pins. I got to checking the bolts in a few hrs and found 50 or 100 ftlb on bolts that should have had 250+. Some joints werent even fully seated to the chassis. I found one bolt position in the chassis "soft" because it was partially stripped to the depth the bolt went. All of the holes were much deeper and I got Mahindra to give me longer bolts to use near the whole hole depth at every position. - Lurking porosity in the casting makes ample thread engagement prudent. - After getting everything tight the loader was much stiffer.
. . . Find out what size and class of bolt is used on yours and observe that thread engagement is at least the bolt diameter. 1.5 bolt dia would be wonderful.​
Check back with the size, class and pitch of the threads and we can determine the torque they will sustain.
The above is probably not the cause of your bucket action. That is probably air in the lines. Be sure your hyd oil is full. Cycle your loader to its extremes. That should help - and should be repeated periodically on the curl circuit to assure both sides of the cyls remain full.​
I dont have much confidence that the loader was installed properly. They did it at the dealership I picked the tractor up from. There are marks on one of the nuts at the loader valve where someone used pliers instead of a wrench. One of my pet peeves..
   / Mahindra 2545 on sand #108
I wonder if the dealer made up the hyd fluid that went into the loader cylinders and loader plumbing. Pls cycle your loader and then check fluid with it elevated to 1/2 height, level bucket. It should be at, or a little above full.
   / Mahindra 2545 on sand #109
Call and talk with everything attachments and see what they recommend for your tractor and your uses. I have the 72" double lid but I move a lot of trees and firewood in the woods, etc. This is what they recommended for my use and tractor size. Our tractors are about the same you have a little more power here and there from the improvements they did from one year to the next. I'm very happy with mine and the cost was not that bad, but I saved for years for mine and It is the one attachment I wanted more than anything. I was a fan of how light the grapple was for the strength, I didn't want a big heavy grapple which would take away from my lift capacity.
   / Mahindra 2545 on sand #110
I didn't have the $$ for the EA, so I got the MTL. They didn't have the smaller one in stock, sold me a 72" for same price. Double lid. Works just fine (on my 2540 with the huge valve!) and the extra weight compared to EA hasn't yet been an issue.
The MTL is mild steel, the EA is a much better structural steel, and likely better designed. But I just don't bang it into stuff, and it's been fine.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
