Mahindra 2545 on sand
   / Mahindra 2545 on sand #11
I have 45 acres of sand. Nearly all of it has been farmed for the past 50 years at least. We are building a house on the site, we are currently under contract. My #1 priority is to get the driveways set up. We are having to put sand clay over the existing sand to get vehicles in and out due to the lack of any structure or settling of the previously farmed soil. Once we get the clay packed down I'll spread crusher run over top. I've got a box blade, scraper blade, a drag harrow, and a really old, heavy bush hog around 6ft. My dad has a mini excavator, I will be using the tractor to move the piles of sandy muck I dig out of poorly maintained drainage ditches. There is nothing large I need to bush hog, I'll likely borrow my neighbor's finishing mower to cut the around 35 acres of weeds that have grown in the past year since the last harvest. I'd like to get a backhoe attachment for drainage ditches at some point since moving my dad's excavator is a pain. I also need to level the property (from where it has been planted, just a couple inch high mounds for the rows), I plan to use the drag harrow and scraper blade for this. I want Industrial tires so when I plant grass in the future I can navigate around in the yard without destroying anything.
I have used my dad's 1526 to spread sand clay and it did a fine job although it bogged down if I tried to scoop dirt while in M speed. It also was not as effective as it could have been due to traction issues on the sand. Plenty of power but the tractor seemed limited by the amount of traction it had with the ground.
I was looking at Geared 4550's and Shuttle 2445's since they are on sale locally. Being used to the 1526, the 4550 just seems too big for my liking. I love the weight but I feel that it is so big that I wouldn't use it as often or on smaller tasks. I may be wrong but I also am thinking about maneuverability and resale value - I think the smaller frame would be more desirable based on my experience looking at used tractors. Homeowners don't seem to want a massive 4500 series tractor. The 2545 is perfect size wise (I feel like I can see what I'm doing with the loader much better) and is easier to get in and out of.
My concern with the 2545 is that it won't weigh enough to benefit from the added HP. Operating weight of the 1526 is 2459lb, the 2545 is 3285lb. I ran some ballasting calculations and can get 1078lbs with 75% filled tires on the 2545. That is 4363lbs total for the 2545, 1900lbs more than the 1526. I would expect that to make a big difference but I literally drove a tractor for the first time 2 months ago. Any thoughts/suggestions would be appreciated.
In your case in particular it seems prudent to check out these tires.
https://www.tractorbynet.com/forums/owning-operating/408601-r-14s-have-hit-market.html
Those look interesting but best I can tell they don't have either size for a 2545. 2545 uses 10-16.5 front, 43x16-20 rear.
I don't see much of an option to buy them, either. I'd be interested to see what they cost.
   / Mahindra 2545 on sand #13
You maybe could apply a little leverage by asking your potential dealer(s) to express interest. :confused3:​
The dealership told me today it could be a week before they can even get me a 2545. Not going to push my luck trying to get tires that came out this month. LOL
Really annoying. They had two 2545's Monday morning. One sold Tuesday and the other had been loaned out. It's supposed to be 70F here this Sunday. I was really hoping to get something before the weekend. :/
   / Mahindra 2545 on sand #15
The weights that you listed for the tractor did not include the fel which is a little over 1000 lbs , The whole package with loaded tires is over 5000 lbs
Excellent point. I need to update my figures I quoted anyway - the dealer I'm working with doesnt do beet juice. They do washer fluid for $150. I doubt I could do it for that cost. I'm a little sick that I don't get the heavier beet juice, though..
   / Mahindra 2545 on sand #17
Re-post: 1st attempt didn't go thru.
I don't have beet juice in my 2538, but some type of anti-freeze (washer fluid?) that the dealer installed FREE for purchasing the tractor thru him.
I've used the FEL extensively, and maxed it out almost daily with the weight of various materials, bucket forks with pallets of flooring hanging out 4' in front of the bucket, and the rear tires never came off the ground, and I don't have any other ballast in the rear. In SC, I don't think you need to be too concerned about beet juice vs anti-freeze. Just my opinion.
I just knew I'd be sick if the weight isn't enough to get traction for scooping gravel and red clay out a pile. I'd always be wondering, "if this washer fluid weighed 25% more...."
I'm looking at grapples, always wanted one. Just like the third function I'm trying to learn what I can now so I can make an educated decision on what to buy later on. Any thoughts on grapples for this size tractor? I mainly want to be able to pick up logs and brush. I'm assuming I wouldn't want a grapple any larger than the standard bucket, 66". I'd buy used, I'm only buying a new tractor because it makes sense. Much like a 4wd truck, used sales prices around here are shockingly similar to prices for new items.
   / Mahindra 2545 on sand #19
If you want more bite for scooping a load of clay, definitely get a toothbar for your loader bucket. It makes penetrating soil and other material piles SO much easier. Also just keep a heavy box blade or other implement on the 3-pt hitch and you'll have plenty of ballast for loader operations. I doubt the weight difference of beet juice vs washer fluid would be very noticeable. Just my :2cents:
For example: 65.5" Toothbar,Toothbars:Skidsteers,Loaders:LIFETIME TOOTHBAR W/REPLACEABLE TIPS | eBay
That looks really interesting. I didn't realize this was even an option for the stock bucket. I'd say that 90% of the times I felt like the 1526 was inadequate I was trying to scoop something but didn't have enough pushing force to penetrate with the bottom lip of the bucket.
Seems like in the end the toothbar would need to be welded in place, I can't imagine it staying tight on the loader and not shifting around after being loaded a couple hundred times. I'd have to change the way I am currently spreading dirt, though - I have been dropping the bucket into float and reversing while it is pointed down at around 35 degrees or so.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2017 Vermeer SC30TX Stump Grinder (A48837)
2017 Vermeer...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
2022 Club Car...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A50397)
Adams Load Out...
