Mahindra 2538 5th year review
   / Mahindra 2538 5th year review #1
BuggyMasters
Statesville, NC
Mahindra 2538
Well I’m in my 5th year of ownership now. I’ve got 160 or so hours. I still stand by this: Of all the major purchases I’ve made in my life, this tractor is at or near the top of my most satisfying and actually worth the expense. I have picked up and stacked trees into a burn pile using the grapple, drug the driveway a million times, created a driveway, moved countless tons of gravel, bushhogged many a acres, reshaped the earth, carried very large heavy things from A to B, and smiled the entire time. I absolutely love this thing. The biggest problem I have is maintaining the self control it takes in not going to buy an even bigger one. Certainly not because the one I got doesn’t do everything I need it to though.
When I first was on the fence about getting a tractor I’m glad I came here and was pushed onto the buying side. If anyone else finds themself in a similar situation, just go for it.
Money well spent.
   / Mahindra 2538 5th year review #2
I'll second that motion! I too, am in the 5th year of ownership. Only difference is I have just shy of 1600 hours on mine. Moved mountains of dirt, gravel, graded ½ mile of drive, mowed 10 acres on a regular basis (finish mower, not bush hog). Moved 100 tons of various aggregates.
I take care of it with proper and frequent maintenance. But so far no real issues. Had to replace a seal on a curl cylinder a year or so ago, and had the ECU updated about 4 years ago.
Purrs like a kitten, works like a mule.
   / Mahindra 2538 5th year review #3
Does anyone know if there are radio wires from the factory on the open station 2538. I know they are on the cab models, not sure on open station. Thanks in advance!
   / Mahindra 2538 5th year review #4
There is a 12v pig tail under the shroud for the fuel tank. I used it to electrify a fan for the open station when it gets 90° or better and humid. Certainly could use that for a radio if you wanted.
Trick is where to mount your radio
   / Mahindra 2538 5th year review #5
Well my thought is to use a fender mount radio as no cab. I think there is room to do that. Thanks for your help.
   / Mahindra 2538 5th year review #6
Hope you're planning on using ear buds for the radio. I'd never be able to listen to one, between the engine noise and PTO implement noise.
   / Mahindra 2538 5th year review #7
going on 6 yrs and 650 hrs , had to replace a hard line underneath last yr , got the part in less than a week was back in business in about 20 minutes, very happy with it.
   / Mahindra 2538 5th year review #8
Does anyone have to part # for the WIX oil filter on a Mahindra 2538 hst open station? Thanks in advance for your help!
   / Mahindra 2538 5th year review #9
Wix engine oil filter: 51324
Wix hydraulic filter: 51586
Wix air: 46489
Wix air: 46490
   / Mahindra 2538 5th year review #10
Thank you for you help, now the only one I need is the fuel filter. Hopefully there is someone out there that has a number for that. Thanks again Duffer!
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2004 INTERNATIONAL 9900I (A52472)
2004 INTERNATIONAL...
DONDI DBR/75 S LOT NUMBER 54 (A53084)
DONDI DBR/75 S LOT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
