Mahindra 1533 HST - install 3rd function valve kit
/ Mahindra 1533 HST - install 3rd function valve kit #1
Krash1533
Beaverton,MI
Mahindra 1533
I am new to the site and looking forward to interacting with you all. Took delivery of my new Mahindra 1533 HST back in August/2017. Looking for a little bit of advice/suggestions/tips, on installing a 3rd function valve kit on my 1533 HST. I have purchased the grapple attachment, next step is to install the 3rd function valve and lines. Where and how is the best way to install the 3rd function valve?
Thanx, Jim
/ Mahindra 1533 HST - install 3rd function valve kit #2
You can save a ton by not putting it in, and simply placing your loader flat on the ground, and swapping the bucket curl, and connecting the cylinder to those ports. The only thing better than cheap is free .
/ Mahindra 1533 HST - install 3rd function valve kit #3
Their are two styles. A diverter valve that diverts flow to the curl cylinders and would then control the grapple instead. The second style is a true third function that would allow all 3 functions at the same time.
WR Long and Construction Attachments (CA) both have true function kits and have good videos on YouTube. They claim these kits have all the hoses etc needed. However the last guy who had the same question ended up having to have hoses made anyway. Probably $1100 or so.
If you want to make your own kit you will need the valve and electric switch and then have the hoses made. You will also need to make the brackets. Probably $600 or so.
I have made a few YouTube videos on the third function for the 1533/1538. Watch those and us know what other questions you have.
Also, as noted above, this question has been kicked around on here. Searching for and reading through those posts may help as well.
