Mahindra 1533 HST good battery, won’t turn on even into accessory mode
   / Mahindra 1533 HST good battery, won’t turn on even into accessory mode #21
Bat terminals pretty clean don't count. They need to be bright and shiny, posts and clamps. Go spend 3 bucks on an HF post and terminal cleaner.
   / Mahindra 1533 HST good battery, won’t turn on even into accessory mode #22
What you have is a lack of maintenance corrosion issue from what I see.
   / Mahindra 1533 HST good battery, won’t turn on even into accessory mode #23
My 08 5530 Mahindra battery was showing 12v and had lights etc;. Took out the battery and had it load tested at our local NAPA. Showed that it had no amps to crank over the starter. Installed new batery and started right off. Batteries are not like they used to be.
idaho2
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
