Made a rain/snow poncho..
/ Made a rain/snow poncho.. #1
wetstuff
Salisbury, Maryland
J-D 1070, Furgeson F-40
I found out the 18' Rider truck body I had here at the shop is about 6" shy of letting my 1070 inside, so I can't take it home .. the garage: same deal/worse. It's supposed to perhaps dump on us in 48hrs, so I had to make a quickie.
I have a load of Green Sunbrella canvas, but this has an extra layer of urethane on the underside which makes it even that much more waterproof. I will probably add a ridge pole from the steering wheel to the top of the seat, but this will at least let me work in a dryish area over the weekend.
Jim
I tweaked this with an aluminum ridge pole within a sleeve on the inside. It will make a Dbl Diamond ski run - when/if we get snow.
In also have a firm memory of a cold butt last winter in a vinyl seat. Like bits of steel -you will weld someday- I keep chunks of fabric.
This fleece was last used as a dog bed. Prior, a seat cover in a BMW 2002 in the late 70's?! Clear grain planks and bits of stainless are always useful - someday.
Have nice holidays.
Jim
/ Made a rain/snow poncho.. #3
I can envision that fleece being wet instead of warm. Make sure to take in in the house and bring it out when you need it. Looks good.
mfruend: The only time it gets wet is when I get off the tractor and forget to tilt the seat forward. Sheepskin is also cool because you can wash it. This 20+yr old piece has been washed many times.
I got to use my cover in ernest in the last couple of days.
I still get snow on the foot wells, but the important stuff if clean.
Jim
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
3ft Metal Ford Tailgate (A65583)
3ft Metal Ford...
Lot 602 (A62613)
Lot 602 (A62613)
2005 Dodge Dakota 4x4 Crew Cab Pickup Truck (A64556)
2005 Dodge Dakota...
2021 Ford Explorer SUV (A64557)
2021 Ford Explorer...
