Mad Max
/ Mad Max #1
Mad max
Victoria
John Deere 2010
Hi. I have a JD 2010 with a blown engine, One sleeve came loose from the top plate and let water into the sump. Water in the oil did not do the crank any good. Does anyone know where i can get a second hand engine or is there any other JD engine that might fit this tractor. eg later model engine.
thanks Max.
/ Mad Max #2
:welcome:
To TBN Max. Well, I guess I can see why you are so "MAD" :laughing: with all those problems.
/ Mad Max #3
No help here but had to Check a post called mad max
/ Mad Max #4
Welcome to the forum.
I'm sorry to hear about your engine! I'm going to move your thread on over to the JD section. It's more likely that someone over there will have an answer.
/ Mad Max #5
Welcome to TBN
JD 2010 tractors didn't get labeled as the sorriest tractor to ever have JD's name/logo on it for no reason. Cut your losses and send the 2010 to the scrap yard.
/ Mad Max #6
Welcome to TBN, and to the John Deere site within.
Going to be tough to find a 50-55 yr old engine, but there are bone yards that might have one.
Is your current engine a diesel, gas, or propane? And are you going to be looking for one or the other for replacement?
How long have you had this 2010 and did it come about all of a sudden?
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
John Deere 2840 Tractor (A64047)
John Deere 2840...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
