Machining question
/ Machining question #1
otlski
Platinum Member
New Hartford, CT
Jinma 204, Bobcat mini Ex, Terramite TLB, Polaris quad, Cub garder tractor
I have an older Italian made horizontal milling machine with a right angle head attached making it effectively a vertical mill. The vertical head takes an MT2 taper. I see that all collet sets that are MT2 have a 3/8-16 inch tapped hole in the end for a drawbar. I have been looking at carbide insert indexable shell mills. To keep as low profile as possible, I might prefer one directly with the like MT2 taper (as opposed to a 1/2 inch collet with a 1/2 inch shank arbor shell mill).
Now the question. Is it a reasonable assumption to make that such an MT2 shell mill will have to come with the 3/8-16 inch drawbar thread?
Note to Mods. Many times I have wished for a specific place to post machining questions. Would prefer to stay on TBN rather than subscribe elsewhere.
/ Machining question #2
You do need to get a threaded arbor for the shell mill and you have to confirm with the vendor what thread it'll use as some will have metric threads or different imperial threads.
/ Machining question #5
FYI- Most older mills don't have the rpm's to make use of carbide(especially inserts). If the shell mill has a large enough diameter that will help, but not likely with the taper of a non-keyed#2.
Thanks for the answers so far. What tool speed would I need? Then I can calculate diameter and rpm to see if it will work.
/ Machining question #7
SFM(surface feet per minute) x 3.82(constant) / diameter(of cutter)
Therefore:
Say your cutter diameter was 2", your carbide specs at 350sfm,
3.82x350/2=668.5rpm
Worst thing you can do with carbide is run it to slow. A #2 taper is pretty small so I would take light cuts with a 2". Maybe look for a 3/4 -1" indexable insert cutter with the proper drawbar thread. Should be all over ebay. There are also #2 holders with set screw in most nominal fractional sizes that will allow for solid shank tooling(shanks with Weldon flats). Again, remember that formula for determining your rpm. This also applies to drill bits. Most run them to fast and burn them up.
/ Machining question #8
The mods don't have control over that. You may want to post a thread in the News/Feedback forum where the owners of TBN can see it. ;)
/ Machining question #9
MT2 just stands for morse taper #2 size most morse taper holders do not have a thread in the end. You might have to do some hunting to find one and I would go with a high speed cutter if you can find holder with threads in end might even consider a fly cutter. If you have a lathe you could even use a morse to staight adapter and tap the end yourself.
/ Machining question #10
You could also cut part of the 1/2" shank off of a standard mill end holder so it can clamp right up against the collet.
1999 Freightliner FL80 Altec A75 75ft. Bucket Truck (A61573)
1999 Freightliner...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
iDrive TDS-2010H...
