SmallChange
Platinum Member
- Joined
- Apr 19, 2019
- Messages
- 778
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
There are a number of references around, including threads here, that explain that breakout force or rollback force is the maximum force a loader can exert at the lip of the bucket by curling with it against the ground, as opposed to the smaller lifting force exerted by the loader arms with the bucket above the ground. Obviously, a claw hammer can pull a nail up with more force in prying mode than if you just try to pull the whole hammer up; that's the whole point of having a claw.
But I *still* don't get what my tractor specs mean:
Breakout force @ pivot pin: 1196.0 kg (2636.7 lb)
Bucket rollback force at ground level: 1234.0 kg (2720.5 lb)
The rollback force listed sounds like my above explanation of either term. But what is the breakout force being described here? There's no vertical motion at the pivot pin, it's a pivot (right?). I see the two forces are very close, but, what are they talking about?
I'm mostly just curious, but can anybody help me understand?
Here are some examples of the definition of breakout force I've found elsewhere (as you can see they vary widely):
"Breakout force is the force available to lift the FEL at the bottom of the pile"
"Breakout force is where any cylinder at power can no longer repond"
"It is the maximun force the bucket can curl at the cutting edge using the curling function"
"the maximum amount of upward force the FEL can generate using all of it's hydraulic circuits combined"
"Break out force is the weight that the bucket can curl or roll back"
"it's the sum off all cylinders available power at any one time, independant of the direction and axis of motion"
"bucket breakout is the curl and regular breakout was measured at the pivot where there would be no curl"
"Breakout force is probably best described as the amount of force or pressure (indicated in lbs per sq inch) required to free an object or load from the material it is surrounded or imbedded in." [Note they are saying it isn't a property of the machine, it's a property of the load]
"Technically (ISO or International Standards Org.), it's the maximum upward force in kN measured 100mm (or ft/lbs and 4" aft) of the cutting edge, achieved by the bucket cylinder(s), that is, the curl function, or in geometric terms the rolling moment around the bucket hinge."
