Let's talk a little about buying a machine tool. The truly most versatile machine tool is the lathe. But to take advantage of this you must be experienced using the lathe. For an inexperienced user, a beginner using machine tools, a knee mill, also known as a turret mill in the Bridgeport type mill configuration, is probably the most useful, though still not the most versatile, machine tool to buy. And this is because lots of turning work is not usually required to make or repair most of the stuff for the folks reading this.
So a mill is to be the first purchase. Once again versatility is in the picture. But this time versatility and usefulness go hand in hand. The most useful will also be the most versatile. And the most versatile will also be the most useful. In my opinion, as a machinist with over 45 years experience machining stuff, getting a Bridgeport type mill is the by far best decision. Even for someone with limited funds. Especially for someone with limited funds. I know, prices are different all over the country. Still, it really makes a huge difference, more than offset by the price difference, to have a machine tool that can do so much more than a lesser machine.
If you can, then you should, look at several machines before buying one. If you can pay a machinist to look at a particular machine that's good. Maybe even better is if you can get a machinist to show you a good and a worn machine side by side or at least close is proximity time wise. Then you can look at machines on your own and not pay for every mill you look at. Maybe then you can make the purchase decision on your own or at least whittle down the prospects so that your paid consultant doesn't need to be paid that much.
If you are for sure going to buy a mill then you will need some inspection equipment. You will need a test indicator And a magnetic base for the indicator. And a 1 inch travel indicator. These same inspection instruments are also extremely useful for evaluating the condition of the mill you are thinking about buying. You should then buy these for yourself ahead of time. Learn how to use them. This may make it possible for you to evaluate a machine on your own. Doing your own evaluation, if you are confident in the use of these inspection tools, may make it possible for you to take your time evaluating a machine, to really take your time, and so make a better decision.
I know, there are other folks with different opinions. They mean well, as do I. And there it is.
Cheers,
Eric
