Tractor Sizing M7060. ... tire / wheel
/ M7060. ... tire / wheel #1
duckduke
Ethel
Ford 5900
Looking at a 2016 M7060 with R4s. MFWD
1). Are the R4 wheels same size as R1s and can I fit the factory rubber R1s on the R4 wheels or will I have t change tires and wheels??? I don't want the R4 rubber and want t know if I can simply get fit the std factory rubber R1s on these wheels.
2). This is a Tier 4 unit. Any concern/issues with regen, etc. ???? Nothing to worry about or should I look for 2014 or prior model year??
Thanks for any input??
/ M7060. ... tire / wheel #2
R1 & R4 tires are never interchangeable. Different widths & the sidewalls on R4s are a lit lot taller.
Not many emissions issues have been reported in general from what I've seen on any Kubotas. A few here & there, but nothing systemic.
/ M7060. ... tire / wheel #3
Regen is absolutely seamless on my M9960 and L6060. That said, the Tier IV nonsense is expensive. A 40 series tractor will be less expensive and easier to work on.
Regarding the R4/R1 issue: Fallon is correct. You will need all 4 tires and all 4 rims to convert to R1s. You will also need F & R wheel centers.
SDT
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
Kubota M6950 (A64127)
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
MIDLAND M510 - 10' HYD LAND LEVELER (A64276)
MIDLAND M510 - 10'...
