Tractor Sizing M7060. ... tire / wheel
/ M7060. ... tire / wheel #1
duckduke
Member
Ethel
Ford 5900
Looking at a 2016 M7060 with R4s. MFWD
1). Are the R4 wheels same size as R1s and can I fit the factory rubber R1s on the R4 wheels or will I have t change tires and wheels??? I don't want the R4 rubber and want t know if I can simply get fit the std factory rubber R1s on these wheels.
2). This is a Tier 4 unit. Any concern/issues with regen, etc. ???? Nothing to worry about or should I look for 2014 or prior model year??
Thanks for any input??
/ M7060. ... tire / wheel #2
R1 & R4 tires are never interchangeable. Different widths & the sidewalls on R4s are a lit lot taller.
Not many emissions issues have been reported in general from what I've seen on any Kubotas. A few here & there, but nothing systemic.
/ M7060. ... tire / wheel #3
Regen is absolutely seamless on my M9960 and L6060. That said, the Tier IV nonsense is expensive. A 40 series tractor will be less expensive and easier to work on.
Regarding the R4/R1 issue: Fallon is correct. You will need all 4 tires and all 4 rims to convert to R1s. You will also need F & R wheel centers.
SDT
NEW HOLLAND T4.105F TRACTOR (A62130)
NEW HOLLAND...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A62130)
UNUSED SDLANCH...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2021 Hamm Compactor HD 70i VV Asphalt Roller (A61166)
2021 Hamm...
New/Unused Brush Cutter for Excavator (A61166)
New/Unused Brush...
