MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,701
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Once you get to this size tractor and this much money, you should get a tractor that will fit your needs now and in the future. You're right, very few people do trade them in, they just learn to live with the shortcomings.
The two main uses you state, food plots and mowing are where more gears are a great feature. Running ground engaging equipment and mowers with plenty of gears can be downright fun as opposed to too fast or aggravatingly slow. Also on the M series Deere and the LS P series you have electronic hi/lo which gives you an extra gear at the push of the button when things bog down.
You should also get at least a 540/750 PTO which is great for mowing with the bigger tractors. Mine has the 540/750/1000 and ground driven feature so I can run anything.
You can get'er done with any of those tractors, for sure. But if you get the 12 speed I guarantee you will be wishing for higher or lower speeds. Not enough to trade it in but you will say to yourself at least, "If I had it to do over again...."
Lack of gears is my number one of only a couple of dislikes that I have with my Mahindra 7520. 16x16 would probably do it for me though. I personally would not purchase another new utility tractor of this size without having at a minimum a 16x16 transmission. While the 12x12 works, there are times when the "right" gear just is not there. A lot of people that have not operated in those types of conditions simply do not understand, but it is a fact and why so many other options ARE out there. If there was no need, there wouldn't be any other options, but there is and there are.
All things that should be considered IMO.
