M7060 Hyd. Toplink
/ M7060 Hyd. Toplink #21
Six, you can add a lock valve to the cylinder, but you lose float.
I don't think I use float or even know exactly how it works. I can guess what a lock valve is but how does it work?
/ M7060 Hyd. Toplink #23
There are cylinders with check valves on them. The valving box on the cylinder is locked shut until a large pressure is applied on either input, then it kicks open. So basically the cylinder can't move until it gets partial system pressure. Applying float at little to no pressure isn't enough to trip the valve.
Those valves add expense & complexity, not to mention kills float. They generally are needed to combat cheap spool valves on the tractor that let the cylinders leak down.
Float just opens both ends of the cylinder to the tank. The cylinder will extend & retract freely based what is pulling or pushing on the cylinder. I love it for mowing to keep the mower following the contours of the ground.
/ M7060 Hyd. Toplink #24
I have the cheapest flimsy toplink on my tractor and it easily handles a 3000 pound aerator without creeping. On 90hp. Sorry poor quality picture, I only had it for plumbing reference til I colour coded every QD with tape. My controls are wacky.. I have one spool that can lock in float, one that I can lock in constant pumping, and one that is single acting with a float position. Handy- but the tape means getting it right for each attachment/implement
/ M7060 Hyd. Toplink #25
This is a stupid question and I should know better, but how do I know if I have "float" on my hyd outlets? Would I merely push the hyd lever forward (or backwards) and if it stays there it has float? I use it for my bucket loader to grade things but never had much other use since I have draft control. Maybe I'm missing something here.
/ M7060 Hyd. Toplink #26
Float is like a neutral. If you are in float then both ends of the cylinder are "dumped to tank" and the cylinder can move in or out as load takes it. Eg my FEL has a float position when i push the stick forward, a detent holds it there, and the loader goes to ground. I used the wrong term when i said i can lock it in float or constant pumping, it's a detent. Float is very useful for disconnecting and connecting, as the poppets in the couplings are free, reducing the effort it takes to plug one in under pressure. I use float on my mower so it can move, on my toplink so I can attach something with ease, etc
No such thing as a stupid question.
To see if your valves have a float pos. it's as you said, it should hold there; but it will sound the relief/safety valve while the system 'deadheads' (oil can't go anywhere but it's trying), but in float all the pressure is released. Put your 3pt hitch right down, and it is in float as it is a single acting system, no down pressure.
/ M7060 Hyd. Toplink #27
I'll add to Pete's offerings.
A non-cancelling, non-float valve handle always springs back to center. There are no detents on either end of the handle stroke.
A self-cancelling valve handle has detents on both ends of the stroke. I use mine when pulling my hydraulic lift wheeled disc. To raise the disc, pull handle rearward into the detent, when the cylinder reaches the end of it's stroke it kicks back to center on it's own. To lower the disc, push handle forward into detent, when the cylinder reaches the end of it's stroke it kicks back to center on it's own.
A float valve handle has a detent in the forward position (lower position) only. This puts the valve into "float" position and as explained allows the cylinder to freely extend/collapse. Pull back on the handle from center and it acts spring loaded like the first valve I described.
I have one SCV and two float valves on my Kubota. The Ford has two SCV valves.
/ M7060 Hyd. Toplink #28
If not to make things even more confusing, but I will add to Richards list.
Typically the 3 position spring return to center valve (let go of the lever and the lever always returns to center) is the most common type of valve and is the most common rear remote valve used on the majority of tractors talked about on TBN.
2nd, a very common valve used for rear remotes is a simple detent valve. This type of valve is intended to be used as a constant feed source for implements such as a log splitter. While these levers do not spring back to the center on their own, (pretty much stay where you leave the lever) they can be used to control a hydraulic cylinder if needed.
Different manufacturers supply different types of valves for their various tractors depending on what they feel the tractor is most likely to be used for. Some tractor manufacturers have valve options for you to choose from.
There are a lot of variables-options, that's for sure. :thumbsup:
/ M7060 Hyd. Toplink #29
They need a 'like' button on here!
Thanks for explaining that better, guys. I have one of each, and one that seems to have little or no reverse flow, that I use on my big tip trailer. Could just be an adjustment required to get it to behave.
/ M7060 Hyd. Toplink #30
Yeah, if you use the "Build a Tractor" portion of Kubota's website, up in the larger Utility class, you choose which type of valving you want.
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
2021 Kubota B2601 (A60462)
2021 Kubota B2601...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2009 Case CX36B (A60462)
2009 Case CX36B...
2017 FREIGHTLINER CASCADIA (A60736)
2017 FREIGHTLINER...
