M7060 bogging down.
/ M7060 bogging down. #21
Seeing as how the problem seems to occur when in use for a period of time, this might indicate a vacuum buildup in the fuel tank. Next time it happens, pop the fuel cap on the tank, or just loosen it, and see if the problem disappears. If so, you have a blocked fuel cap vent.
/ M7060 bogging down. #22
PSB-2021-007-E-R1
Is the bulletin number.
Issue:
There is a possibility that engine power may drop at operating temperature. The nozzle body may not open/close due to an internal failure of the injector. (Other than contamination in fuel)
This is covered for 5 years from date of original purchase, no hour limit.
Many people have complained about low power issues, and now it is a known issue. Had one customer that went so far that he bought another brand because the power was low, never got the Kubota service reps involved (dealer didn't help), just complained about the issue. The rep took a 5 min look at it, yep, bad injectors, and had the dealer install new. Power is fine, customer was now upset at the dealer (of course) and at himself for buying another machine. He liked his Kubota other than that low power issue.
Hope this helps.
I suggest testing fuel supply pressure, you just might be surprised by the result, then consider fluid dynamic cavitation affects on fuel injection components. It leads to low power and misfire after a length of time running under considerable load. Injector replacement won't correct low/no fuel supply pressure to the high pressure pump and resulting fluid dynamic cavitation.
I have been through a low power problem with an M7060 after 1-2 hours of use that required most of the engine horse power. I suggest you measure fuel pressure at the fuel filter inlet while running under load. As long as you have proven that you don't have a fuel restriction before the electric fuel pump, you have a serious problem on your hands. Contact me for details.
Thanks. I sent you a pm asking that you give me the details over email. I appreciate all the help.
If this works, I owe you a steak dinner! I doubt my luck could be that good but it is certainly worth a try.
Certainly makes sense as I've filled the fuel tank after each cutting.
/ M7060 bogging down. #25
But replacing faulty injectors at no cost as called out in the bulletin an and has fixed the identified problem. The OP can jack around trying to diagnose it himself or he can let a qualified dealer hook up his Diagmaster and run the proscribed tests and checks to verify the faulty injectors.
/ M7060 bogging down. #26
The Diagmaster will not measure fuel supply pressure to the high pressure pump. The more information the tractor owner has about what causes low power after extended use at or near rated power, the better he will be equipped to discuss the problem with the technical people at his dealership. When that information comes from someone that provides engineering based test data about the problem on the same model tractor, it is a benefit to the tractor owner that has posted on this site to get to the bottom of the problem he is having. Replacing the injectors may just be a temporary repair, my input to the owner is intended to help him get to the root cause of the problem. That is how true diagnostic testing is done.
/ M7060 bogging down. #27
We don't require our customers to diagnose documented problems covered under warranty beyond normal maintenance items and in this case visually verifying flow to the high pressure fuel pump. Beyond that it's our job to complete the diagnosis and make repairs so the customer can get back in service. The OP can follow all your advise if he wishes, I don't really care. As I said, the information provided follows a known pattern for this particular fuel injector installed in this model tractor. There is no pattern of low pressure in the common rail associated with this failure. Low fuel supply volume would lead directly to low rail pressure IF it were the cause of the OP's symptoms. There would be stored codes for low rail pressure discovered in the dealer's diagnostic process.
We have been down this road and to date full set injector replacements have not been temporary repairs.
I don't know or care what your background is, I'm reporting from my direct knowledge about what I perceive the OP's problem to be.
/ M7060 bogging down. #28
You are incorrect, you can have a negative suction head pressure to the electric supply pump, there will be no codes set, no loss of fuel rail pressure until that negative pressure gets so great that the high pressure pump is starved for fuel. I have measured this.
Do you have test data to verify fuel flows and pressures in that fuel system? I do!
/ M7060 bogging down. #29
Like I said, I don't care what the OP does. Chances are very, very slim he's going to cure his problem by retaining his current fuel injectors. That's my concern. He can ignore me or not, and you can call me mistaken all day long but fuel starvation to the point of affecting performance WILL set a high pressure code. Like I said, there is no pattern of low rail pressure associated with this failure. I am most certainly not incorrect making that statement.
Your comments about supply are not necessarily incorrect but they also do not contradict a single word I posted.
/ M7060 bogging down. #30
Oh, I am not questioning that the injectors can have a problem. You are missing my point, the root cause of the problem needs to be determined. I offered advice to the tractor owner so that he can get to the cause of the problem. Just for the fun of it, what is the fuel pressure spec for the M7060 measured at the fuel filter inlet or the outlet for that matter? What is the flow rate vs pressure for that little electric fuel pump? What is the total fuel flow in that system, fuel consumed plus fuel returned? I bet you don't know that!
Thanks to all for the information. I've spoken with my dealer and they are on top of it. They mentioned most of what you guys said but are leaning toward a fuel injector issue. I'll have it brought in.
I'm lucky to have a dealership with a great Service Manager.
Thanks, again, to all.
/ M7060 bogging down. #32
Hopefully they can solve your issue in short order, it would be interesting to know what your issue is, for those of us with this Tractor!
/ M7060 bogging down. #33
Service manager is really nothing. It's the tech in the shop who will be the person to analyze and fix the issue.
/ M7060 bogging down. #34
I have a M7060HD12 and just spoke with my dealer regarding this PSB. I haven't seen the low power issue yet (less than 150 hours on mine) but wanted to be proactive just in case. He stated this PSB is a fix as fail warranty. I just thought I throw that out there for anyone looking into this.
It is in the shop and they warned me that it may take a week or two. Thanks, again, for all the advice.
Got the tractor back today. Cut the grass with the PTO at the economy mode and had no issues. Not much strain with that grass, though. Didn't get to take it to the field as a storm rolled in and the fields are wet.
Tractor ran normally. Time will tell.
Thanks, to all, for the assistance.
/ M7060 bogging down. #37
Glad you got it back. What did they find?
/ M7060 bogging down. #39
RickB is correct. Low supply to the high-pressure pump DOES set DTCs. The most common is a leak in the high-pressure fuel system. It is the same code you get from a plugged fuel filter. All the electric pump needs to do is supply a minimum of 2 PSI fuel to the high-pressure pump and not have wide pulsations. Fuel flow beyond that is as irrelevant as the rear tire air pressure.
I have encountered this complaint several times. Connect Diagmaster, perform the 8 injectors shut down tests. Look at the wave pattern from the injectors. Send a copy of the file to Kubota service assist, they will instruct you whether or not to R&R injectors.
/ M7060 bogging down. #40
Have you actually tested an M7060 under load while measuring fuel supply pressure to the fuel filter, fuel rail pressure and horsepower? I will save you the time, while fuel supply pressure to the inlet side of the fuel filter is at -2 PSI, rail pressure remains within the range to not set codes and the tractor seems to run normally except power is somewhat lower. Now, while the fuel supply pressure is that low and the fuel temperature gets higher you get fluid dynamic cavitation, continued use under that condition destroys high pressure fuel system components. Eventually a misfire and substantial reduction in power output. But, no codes are set!
HEAVYEQUIPMENT PRESSURE WASHING PARTS (A68842)
HEAVYEQUIPMENT...
2018 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A65057)
2018 CHEVROLET...
PORTA POTTY (A68842)
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
CAT J600 Teeth (2) (A68134)
CAT J600 Teeth (2)...
