Oil & Fuel M7040 fuel level question
/ M7040 fuel level question #1
keving
Virginia/WV
Kubota 7040HDC
I just refueled my 7040 for the first time. It has a 29 gallon tank and the fuel gauge was at about 1/8 tank. I could only fit about 12.5 gallons.... Is this a REALLY bottom heavy tank?
/ M7040 fuel level question #3
It holds 29.1 gal for the cab version and 18.5 for the ROPS version. I've never let mine get very low. Maybe 2/3 of a tank before refuelling. How many hours did you have on it when you refuelled? Even though fuel consumption is going to vary depending on application and engine speed that may help give some insight into your question. It does sound like it's very bottom heavy though. Did your low fuel light come on yet?
I had a about 20 hours on her at that point. The fuel light did not come on and I was not doing high RPM work. It is the cab version with the 29.1 gal tank. How is your fuel economy?
/ M7040 fuel level question #5
I dunno; hard to say. Like I said, I keep it topped off. But I have about 26 hours on it and have probably only put in about 12-15 gallons at most. Most of that is heavy loader work at about 1600 RPMs. So I'll bet that the tank is pretty bottom heavy. You could send m7040 a PM, I'll bet he would know since he has the cab version.
/ M7040 fuel level question #6
keving, I have almost 200 hours on mine. Ran it low to where the low fuel light came on and it took about 29 gallons to fill up. With heavy lawn mower work it uses about 1 gallon an hour. Any other type of work use less because of lighter loading
John Deere 490E Excavator (A62679)
John Deere 490E...
Transfer tank (A61567)
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
Great Dane Van Trailer (A63689)
Great Dane Van...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
