M7040 and Rhino Turbo 96
   / M7040 and Rhino Turbo 96 #31
Maybe use it to clear some snow one of these Winters.... Lol (some pics from my buddy checking on our place for us). You guys said you like pics.
Great pictures!!!! We'll look at all those you have!!!!
I have no concept of that much snow. I have a friend that lives in Southern Colorado. I've went out there in Winter. I've also 4-wheeled over a lot of Colorado. Sometimes in early Spring. It's amazing to me the amount of snow you still see in mid Summer!!!!
   / M7040 and Rhino Turbo 96 #32
wbuffetjr1: I wanna go too Daddy !!!
That one pic is painful to see. I got hung in deep snow, alone on a snowmobile, in Utah once. Had to hike out for help.
Beautiful. Thanks for sharing. By the way -- Dave above is your best/at least a great/ source for anything about your 7040.
From the "unload off the trailer" point to the "in my meadows" point, how far do you have to move the tractor and cutter under it's own power ?
   / M7040 and Rhino Turbo 96 #33
Some of the trails to get to the meadows are pretty tight. The FEL will make access to some of them more of a PIA, but I am sure it can be done. Maybe leaving the FEL attached is the best option. I am sure I will learn what's gonna work best as I get to know the tractor. Hauling it out to the mountain in July.
You might try just removing the bucket or forks and leaving fel on to reduce your length a little.
Are you aware there are two positions on the lower 3 pt arms for the lift links to attach to?
They are close together. One hole gives the ability to lift heavier weight at the expense of a bit of height loss.
The FEL on a M7040 has the same ability with the lift arms of the loader. More lifting strength or more lifting height.
Dave M7040
Thank you Dave. I moved the 3 point arms to the lower holes and both lift cylinders to the power position. So far the tractor has had NO problem lifting the Turbo 96. Doesn't seem to be an issue at all. Just concerns me that it is 800lbs heavier than what kubota recommends.
Ovrszd - Great pic! I would almost guess that pic is from Ouray, CO? Maybe Engineer or Imogene Pass? If so, the tractor will wind up about 35 miles from there! We spend a lot of time out that way and will permanently live out there in a few years.
JWR - Winter out there is no joke! Especially in remote areas it can become dangerous real quick. People do not realize how fast you can become immobilized if you have to travel in 4' or so of powdery snow with no shoe shoes!
Not counting helping mow any of my neighbors places, I have ~10 acres to mow out of a 40 acre lot so not too too far from the driveway to the any of the meadows. I do think I will use it "semi mounted" some just to try to take it easy on the tractor. I do not have a hydraulic top link or any of that. The Turbo 96 just has 2 manually adjustable wheels in the back.
4 years ago I started mowing these meadows, planting, clearing other ground, etc trying to improve the habitat around our place. We have cleared ~5 acres of HEAVY timber that was chock full of major deadfall. Hoping to use the 7040 for more clearing, moving downed timber, hauling rocks for habitat for our pond, etc.
All this hoping to improve the hunting situation. Then got this pic this past year!! I love it when a plan comes together!
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
SDLanch SDLE20 Mini Excavator (A57149)
SDLanch SDLE20...
CEA 9' Rake (A57148)
2013 Vermeer BC1000XL Towable Brush Chipper (A56857)
2013 Vermeer...
Niles Pond Engine Lathe (A59213)
Niles Pond Engine...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
