M6800
/ M6800 #2
I'll bet you do like it./w3tcompact/icons/smile.gif Have fun in comfort./w3tcompact/icons/wink.gif
Bird
/ M6800 #3
If you decide you don't, I'd sure like to hear why! /w3tcompact/icons/smile.gif
Mark
/ M6800 #4
I certainly like mine and am sure you will too. The M6800SD is a lot of power in a small package. I haven't found the first thing that I didn't like and I sure found a lot wrong with my last tractor before this one! /w3tcompact/icons/smile.gif
/ M6800
My 16 year old boy has been mowing on it.He may even take his girl out on it he likes it so much.Washes it every day.The 3 point hook up is very easy to use.So far so good.
/ M6800 #6
Wen or Saltyhorse,
Any trouble with the tires? After about 5 hours of bush hogging my fields with my M9000 the other day I was heading for the tractor shed when I noticed the smell of antifreeze- thought I had busted a radiator hose and I was watching the temperature gauge as I drove, but it did not budge. I then noticed something splashing on the side window, so I stopped and found fluid leaking from around the valve stem off a rear tire. My dealer said that I must have punctured the inner tube on the thorn of a locust tree, although I can't find any puncture site. Can the inner tube burst from normal use? He is coming out tomorrow to pick up the tractor for repair. A down side of the cast rims is that each tire/wheel weighs over 600 lbs, hence not something I can pop off and take in for repair. Any tricks to handling a 600 lbs tire?
/ M6800 #7
If you have both 600 # rims and anti/freeze in the tires, you need a tire truck unless you have another tractor with a loader to pick them up and put them on a trailer.
The tires are pretty hard to puncture, but nails or thorns can certainly do that. I have tubeless tires, but for a puncture it wouldn't make much difference, the tire has to come off either way. Be sure to watch the anti-freeze unless it is the non/toxic type as it tastes very sweet and pets and animals drink it and die shortly from kidney failure (terrible stuff).
I have yet to have a flat on an Ag type tire. Had quite a few of them in the 2WD front tires on my last tractor. Just put plugs in them and kept going. That is what I would do with the tubeless tires also, but that won't work on tubes. Always possible to pinch a tube putting it on and have it fail later - the tire guy will tell you what happened if you ask him.
/ M6800 #8
Saltyhorse-Sounds like you got yourself a real toy, I mean tool. Hope you will register and keep us up to date on your new tractor. Makes us guys with little tractors ponder the possiblities.
/ M6800
No trouble with the tires yet.But I am not sure if they are inflated with the right pressure.
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
John Deere Z915E Zero Turn Mower (A66408)
John Deere Z915E...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
2015 TAKEUCHI TB280FR EXCAVATOR (A65053)
2015 TAKEUCHI...
